C7 RS6 Towing advice
superlightr
Re: C7 RS6 Towing advice
Post by superlightr » Sun Feb 26, 2017 9:00 am
cant help with a number but thought this thread deserved a pic ---
:biggrin3:
doodlebug
Post by doodlebug » Sun Feb 26, 2017 9:03 am
That's so wrong. Don't suppose someone dropped a car on he van top gear stylee?
superlightr
Post by superlightr » Sun Feb 26, 2017 9:51 am
if you get overtaken by a van your going too slow....... ;)
fun to out drag cars at lights when towing as well....
doodlebug
Post by doodlebug » Sun Feb 26, 2017 9:57 am
Without doubt!!
Knobby
Post by Knobby » Sun Feb 26, 2017 3:27 pm
Brilliant!!!
I'll be towing my track car so not quite as big..
Sounds like my current C7 Quattro detachable tow bar will do the job..
Bit_evl
Post by Bit_evl » Sun Feb 26, 2017 5:58 pm
Just for a laugh given the subject - https://www.youtube.com/watch?v=5Ea7k3VAdi8&t=5s
PhilMorrison
Post by PhilMorrison » Thu Nov 07, 2019 7:05 pm
This thread was very helpful in deciding to go for an RS6 & retrofitting the tow bar. So I thought I'd update it with a slightly cooler picture than the caravan.
crapbag
Post by crapbag » Sun Apr 12, 2020 3:32 pm
Hi Phil
I’m on the process of looking for my perfect RS6 and want to retrofit a towbar if it doesn’t have one. What parts did you use? A direct plug and play kit?
Craig.
PhilMorrison
Post by PhilMorrison » Sun Apr 12, 2020 4:07 pm
Hi Craig, just the OEM tow bar. The car came with 'Tow preparation' in the spec (As most of them do I believe), so they just bolted it on as far as I know. I had it done by Audi when buying the car. It's not as posh as the one I specced from new on my Macan GTS that electrically deploys, but it's still simple enough to drop & kick back up into place. The only grubby bit is the trim panel that you have to remove & refit each time.
Daveperc
Post by Daveperc » Sun Apr 12, 2020 4:15 pm
Just remember you can't fit the towbar if the car has DRC - only air.
crapbag
Post by crapbag » Sat Apr 18, 2020 2:04 pm
Thanks for getting back to me Phil (for some reason i never received a notification)
I have since put a deposit on one, I decided to go for a DRC car as this is going to replace my E46 M3 and R36 so wanted something a little more dynamic when pushing on! so I'll have to forfeit the towbar, unless I can find a way to move the accumulators and reinstate the factory wiring and coding :shock:
On another note Phil, keep up the awesome content, sweet work on the tyres for the 964 and no compromise resto on VITEN
Craig.
viio
Post by viio » Wed Jul 15, 2020 8:36 pm
Time for another revival of this thread! Did anyone ever get the part number? I'm waiting on Westfalia returning my call, but perhaps the Audi part number would help if I need to just take it to the dealership.
bakerdcb
Post by bakerdcb » Wed Jul 22, 2020 7:03 pm
I was hoping to fit a towbar to my 2017 RS6 Performance but it turns out I can't apparently. I approached Automotive Control (Bristol) because they have a nice clip on their website of an RS6 with a detachable towbar fitted and according to them it's nothing specifically to do with DRC or indeed anything other than the VIN Plate information on the driver's door pillar.
Imagethumbnail by Deane Baker, on Flickr
In order to be homologated for towing you must have a 'total weight figure' for vehicle and trailer visible in the missing gap between the 2580KG and the 1290KG. In most cars this would be between 3000KG and 5000KG. If it's missing, as in the case with my car, the car is not approved to tow. I asked them if this was because of the DRC, which is fitted to mine and they said no. Apparently they have successfully fitted towbars to RS6s with DRC. I was told it is most likely due to a particular combination of options fitted at the factory that meant Audi did not approve that particular vehicle for towbar fitting, even though it will have all the same basic wiring and housings.
I'm now trying to see if there is a way around this but it seems unlikely or unwise......or both :?
crapbag
Post by crapbag » Wed Jul 22, 2020 8:53 pm
I had exactly the same response (which I don’t doubt) with Automotive control.
I didn’t look any further into it. Even though it would be highly useful to me. The only thought I had was if the SVA could certify it. But not sure if they could or even would.
Let me know if you do stumble onto any useful info.
Craig.
Tadass910
Post by Tadass910 » Wed Jul 22, 2020 9:17 pm
:audibash:
Users browsing this forum: No registered users and 229 guests
