Winter tires, what pressure do you run?
In short, last year I inflated my 20” winter tires at the same pressure as my summer tires. (front 2.8 and rear 2.5 bar)
Never had issues, handling is good and tire wear on 8k km is even
But recently I noticed the Sticker has a higher pressure for the winter tires!
So yesterday I changed my tires to the winter set and inflated them as sugested. (Front 3.2 and rear 2.9 bar)
Usually there’s just me and the misses an mostly no luggage.
I found the ride to be a bit harsh compared to last year. You feel every bump in the road...
What pressure do you guys run?
Why would they suggest a higher pressure?
All black B9 RS4
Re: Winter tires, what pressure do you run?
I read that as suggesting a higher pressure ONLY when exceeding 250km/hr with 20" M+S tyres.
Correct, mine runs 280.
Winter tires are rated at 270.
So strictly compared in the same circumstances summer is lower pressure as winter tires.
All black B9 RS4
I think it refers to the speed you are (or will be) travelling at, not the maximum speed your tyres are rated for.
I don’t know, it is the only pressure they mention for 20”?
Wear on the summers and winters (only did 8k km on them) is good and even with the same lower pressure.
I kinda prefer the lower pressure for the winters.
Maybe someone knows the reason for the higher pressure?
All black B9 RS4
My tire dealer replied, those pressures are too high.
He advised running the same pressure as my summer tires.
The ride quality sucked at the advised pressure.
All black B9 RS4
interesting no pressures for the 19" option on your Sticker
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
so they are
doh! i must stop masturbating its playing havoc with my eye sight
According to the quality and safety standards, it is recommended to inflate your winter tire up to 30-35 PSI.
I run 38 psi front 35 psi on 265 35 19 winter tyres
Users browsing this forum: No registered users and 55 guests
