A groan or sigh from the engine bay after light throttle
ChrisYates10
Post by ChrisYates10 » Sat Oct 05, 2019 10:43 am
Hello,
I've noticed that at about 30mph when I come off the throttle, there's a slight 'groan' or 'hmmmmm' from the right hand side of the engine bay. If I slow down to 25mph and gently accelerate, releasing the throttle at 30mph, I can hear it every time. It's not very loud but I wasn't aware of it before.
Has anyone experienced anything similar? Does anyone know what it might be? I thought it might be a turbocharger with a dodgy bearing / imbalance or surplus boost being exhausted.
Any thoughts?
Also, I'm getting a vibration / judder when I brake from 75mph, so I think a pair of discs will need replacing, not sure which end. I've looked at all discs and there's hardly any wear. Could it be anything else?
Thanks,
C
Markp
Re: A groan or sigh from the engine bay after light throttle
Post by Markp » Sat Oct 05, 2019 1:04 pm
Turbo? Vacuum leak?
And vibration likely to be discs - first sign is typically lightish braking from speed (classic is motorway slip roads). Felt in steering = front, in seat = rear but often surprisingly hard to tell....
May not be new discs required, just pad deposits, which you might be able to fix with some heavy braking. Or a skim if loads of disc left.
Post by MikeFish » Mon Oct 07, 2019 5:51 pm
Did you fit a set of these and forget about it?
https://www.forgemotorsport.co.uk/Audi_ ... -1454.html
ChrisYates10
Post by ChrisYates10 » Mon Oct 07, 2019 7:24 pm
Hi Mike,
Do you think it might be a leaking / ruptured solenoid valve? I've definitely not fitted any of the Forge ones. My memory is bad, but not that bad. :-)
Who do you use to service / repair your car btw?
C
brab
Post by brab » Mon Oct 07, 2019 11:25 pm
viewtopic.php?f=76&t=120383
I think you are referring to the same thing. :)
My car has now 60,000km and it runs just fine, but the noise is still there.
Dealer confirmed the car is OK.
Regarding the discs, just do a couple of hard braking maneuvers and it will stop.
Post by MikeFish » Tue Oct 08, 2019 8:00 am
Hi Mike,
C
If you had a boost leak I think you would notice the loss in power.
I used to service my car at the main dealers. Might not be the cheapest or even the best but they have known to pay for new engines outside of warranty if its a genuine engine failure and has had full main dealer service history.
For brake pads / discs etc I'd take it to a local specialist.
uplandsway
Post by uplandsway » Tue Oct 08, 2019 8:30 am
MikeFish wrote:Did you fit a set of these and forget about it?
One tried Mike and didn’t like, back to stock for me Image
Cheers,
Stevie F
2016 C7.5 RS6 Performance
PSB1
Post by PSB1 » Tue Oct 08, 2019 1:50 pm
Hello,
Any thoughts?
Thanks,
C
Has your wife climbed under the bonnet?
Toady1
Post by Toady1 » Tue Oct 08, 2019 5:04 pm
Your discs could just be pad material built up on the surface. They need cleaning with an abrasive disc (not grinding disc!!). The noise could just be the recirculating bovs, check your air boxes are together properly.
ChrisYates10
Post by ChrisYates10 » Tue Oct 15, 2019 12:49 pm
Thanks everyone for your responses, C
Users browsing this forum: No registered users and 115 guests
