Hi everyone, I need one of the turbos to be reconditioned as it is leaking, so as the job is quite big I’m going to get both done ... while the work is getting done is there anything else worth doing ??? Any help will be much appreciated thanks
C6 Reconditioning turbos anything else?
Jim Haseltine
Re: C6 Reconditioning turbos anything else?
As the engine has to move to get the turbos off, the oil pump shaft seals and 'the' coolant pipes if they haven't been done recently.
Ok thanksJim Haseltine wrote:As the engine has to move to get the turbos off, the oil pump shaft seals and 'the' coolant pipes if they haven't been done recently.
Jim Haseltine
Turbos are IHI model RHF55 sub-model VVA1. Bearings and seals are standard RHF55. I've yet to restart my car so mine may or may not leak anymore....
Ok thanks, yes they are a pain! My gear change 3rd to 4th seems to jump and is not smooth like the others, will have to get that looked at nextJim Haseltine wrote:Turbos are IHI model RHF55 sub-model VVA1. Bearings and seals are standard RHF55. I've yet to restart my car so mine may or may not leak anymore....
Have you just bought this car?Ads50 wrote: ↑Sun Sep 22, 2019 3:23 pmOk thanks, yes they are a pain! My gear change 3rd to 4th seems to jump and is not smooth like the others, will have to get that looked at nextJim Haseltine wrote:Turbos are IHI model RHF55 sub-model VVA1. Bearings and seals are standard RHF55. I've yet to restart my car so mine may or may not leak anymore....
Yea bout 6 monthsToady1 wrote:Have you just bought this car?Ads50 wrote: ↑Sun Sep 22, 2019 3:23 pmOk thanks, yes they are a pain! My gear change 3rd to 4th seems to jump and is not smooth like the others, will have to get that looked at nextJim Haseltine wrote:Turbos are IHI model RHF55 sub-model VVA1. Bearings and seals are standard RHF55. I've yet to restart my car so mine may or may not leak anymore....
Users browsing this forum: Jim Haseltine and 48 guests
