Hi All,
Taking my car into Audi in a couple of weeks for a service and full carbon clean.
My dealership now has an OEM Walnut Shell blasting machine and charges $1000 (AUD) for a full clean including chemical clean for the intake manifold.
Just wanted to check whether there should be anything else I should get inspected whilst they are there?
I also plan to get before and after photos of the valves. Roughly speaking do you think it is possible to gauge how much power the car might have lost?
Carbon Cleaning In 2 Weeks
R8 V10 Gen 1 • Phantom Black • Coupe • Gated Manual • Quicksilver Valveless Exhaust • REP RamAir Filters • CF Interior/Engine/Side Blades • Wireless Apple CarPlay
RS4 B7 • Phantom Black • Centre Resonator Delete • Wireless Apple CarPlay
SQ5 TDI • Ibis White • Fully Optioned • Wireless Apple CarPlay
Re: Carbon Cleaning In 2 Weeks
Mileage? You might want to change/clean your injectors, change the 2 fuel pressure regulators, the PCV, some of the solenoids / check valves that are underneath the intake, the figure 8 seal that goes at the base of the oil housing and the valley pan gasket.demon8991 wrote:Hi All,
These are the things I can think off and some could be dependent on the vehicles mileage. In any case you might as well take advantage of the shared labor given that the Intake Manifold is off
Sent from my iPhone using Tapatalk Pro
It has done 136,000km.
Without the receipts in front of me, I know it had its last clean around 30,000km ago however that was before my ownership.After that clean was done it did a lot of city driving, hence why I am getting the work done.
Thanks so much for the advice, I will mention it to the technicians.
Well here are the results, work done by Audi.
Would anyone be able to give me a rough esimate as to how much power I might have clawed back?
Before
After
Before
After
Interesting pics but unfortunately the last two of the 'After' (which are probably of sparkling valves) are not showing.
Apologies, is that working now?
Users browsing this forum: Majestic-12 [Bot] and 59 guests
