It's about 4 years since the last cambelt change on my RS6, but the cars only done 12k miles since this was done.
Should I still get it changed or can I wait a bit longer as there's not been much wear on the current cambelt?
Also what's the going rate for a cambelt change these days if I do go ahead?
Thanks!
Cambelt change - yes or no?
Re: Cambelt change - yes or no?
hello to you the first expired mileage or years for the shot years you can ride with some time but at your own risk builders expect an average of 4 years with horses and the couple on a car like ours I would take not the risk at us in concession audi the intervention costs 2500 € deposited rests with all the rollers
Envoyé de mon POCO F1 en utilisant Tapatalk
I wouldn't mess about . I go off age as I only do a couple of thousand a year . I dunno what the going rate for labour is as I do all the work on mine myself, but a belt kit with tensioner, waterpump , thermostat and all the bits and Bob's is around the £500 mark through TPS .
Cheers Al
I don't do many miles in mine either. I'll probably change my belt after 5 years.
I'm doing the same. <15k, but 5 years on the belt next month so will be doing it imminently. Although 200 miles to do on it this afternoon.
for the part I got it myself kit distribution + water pump 350 € + more or less 100 € liquid cooling oil filter oil and other, 1 day of work
Mine was done 4 years ago but has only covered 7k since then in mileage so I’m happy to sit on it for a little while longer. Being in the trade I’ve seen cars at 120k-150k and 10 years old on original belts, one that stick to mind was a Clio 182 on 130k and he tracked it regularly!
Steve2003rs6
Mine was done last year cost just under £1000 parts and labour and vat. Audi parts but not Audi labour.
Always worked on the basis of 40000 miles or 4 years whichever came soonest.
Users browsing this forum: Bing [Bot] and 179 guests
