Early shift between 1st and 2nd
5.0 V10 50v biturbo - 571 bhp
floatdrop
Post by floatdrop » Mon Sep 09, 2019 7:26 am
Greetings from Australia,
WOT, trans shifts at aprox 5000 rpm rather than redline. Just had injectors ultrasonically cleaned and inlet ports de-carbonised. Mapped, BMC filters and sec cat delete, all a couple of years ago. 660hp at wheels. Transmission map is std. Could the transmission map be upshifting early due to higher than expected torque?
welwynnick
Re: Early shift between 1st and 2nd
Post by welwynnick » Mon Sep 09, 2019 9:19 am
What happens if you accelerate at less than full throttle, so the torque isn't higher than expected?
Nick
floatdrop
Post by floatdrop » Tue Sep 10, 2019 1:33 am
Hi Nick
50% of WOT, manual shift off paddles, still changes automatically at 5-5500 rpm.
welwynnick
Post by welwynnick » Tue Sep 10, 2019 8:40 am
When did it start behaving like this - was there a particular trigger event?
Nick
floatdrop
Post by floatdrop » Wed Sep 11, 2019 1:20 am
Nick,
After the injector and carbon clean.
I had the transmission rebuilt around 18 months ago, had them check it, oil looks good, no fault codes. Leaning toward something not connected correctly after the clean.
