Suspension problem
Re: Suspension problem
Pretty sure the best setting on the PSS9 is 4, Shopp will be able to confirm.
Are you having the anti rollbars replaced? They make the car handle ALOT better! Depends how you want to drive it, they are a must in the C5 if you plan on driving it hard.
Steve2003rs6
Hi chunky 79. I don’t drive the car hard. So at the moment don’t intend on replacement of the anti roll bars just yet.
Going to unit 20 For top mounts and pss9,S
And poss control arm problem.
See my thread “loss of brakes”
Thank you for your info
Steve2003rs6
All done. B16 pss9,s and top mounts installed on each corner.
A lovely comfortable drive home.
A very happy RS6 c5 driver.
V!per wrote: ↑Sun Aug 25, 2019 2:13 pmViper,
If it’s just a flexible hose & rigid pipes are sound, why not just replace it?
I did recently at unit 20 with DRC service, not expensive. ( about £300 I think)
Good luck
Ric
got more details ??
Just had the most dreadful ride home ever - a whole 900 miles. One of DRC Rubber pipes(Front Right) popped and all the oil left the system. first I saw a cloud of smoke I thought I killed another turbo. but it cleared in few seconds and straight away I felt how awful the ride became.
Was thinking of going KONI Shocks + Standard RS Springs way
Just in case someone's interested, I have here a full set of 4 DRC shocks, brand new oem in the box for cheap. Finally decided to go the Billstein route 'cause it's quite difficult to find someone to fit them properly where I leave.
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
"Standard springs with Koni shocks will be a pretty good setup for road use I would have thought"
^this^
Too late I know, but this is a great option, 2nd best only to DRC in my opinion. I've had the luxury of having driving many rs6's with different setups and most were awful.
My previous ride had koni yellows with stock springs and my current has a full functioning DRC. When the DRC fas I will be going to koni yellows again.
Glad you got yours sorted, a nice quiet smooth ride just helps enjoy the beast even more, congrats!
^this^
Steve2003rs6
Thanks. Started on setting 4. Roads round here are crap. Reset to 6.
Will now set to 5.
Think I will be more than happy with that.
Regards steve
Will now set to 5.
Regards steve
Steve2003rs6
Just to Finnish off. Took car to local garage to have the wheel alignment done. Track rods seized could not move the locknuts. Went back to unit 20. New track rods installed and they set up the wheel alignment.
Nice drive home.
Nice drive home.
Yeah, that's the setup I have and I'm happy with it.
fukinavit wrote: ↑Thu Sep 12, 2019 9:18 am"Standard springs with Koni shocks will be a pretty good setup for road use I would have thought"
^this^
Well - Got the Billies in yesterday - WHAT A difference. You do feel every single crack and stone from the road but it's not a bothering feel. Car feels sooooo much stable and goes in corners so nicely. Should have done it the first time.
Steve2003rs6
Nice one viper. I am so happy with mine after the awful H&R set up I inherited.
Users browsing this forum: srichards and 256 guests
