BMC filters and MAF's?
5.0 V10 50v biturbo - 571 bhp
c3nturi0n
Post by c3nturi0n » Wed Aug 14, 2019 12:48 pm
afternoon all,
hope you are enjoying summer hols (mainly applicable to those outside the UK at least).
I recently changed my car's air filters to new set of BMC's... everything was brilliant, super high boost and it worked as expected. After 3k miles and while being in Europe i noticed that it sometimes kind of "stutters" at around 2.2-2.5k rpm and then it boosts fine from ~3k rpm. I do not notice that while stationary and with revs up.
Nothing reported on VCDS and i wonder if BMCs caused MAFs to clog up a bit? or am i talking absolute nonsense :bash: ?
Any advice welcome.
ps. least to say is that i did manage to clock 205mph en route to Stuttgart :beerchug: .
2008 RS6 Avant (Monza Silver)
- H&R ARBs
welwynnick
Re: BMC filters and MAF's?
Post by welwynnick » Wed Aug 14, 2019 1:58 pm
It's hard to believe that an air filter change could cause a delayed and speed-specific hesitation, and lots of people use them already.
It won't be down to the MAF's though, because there aren't any. The RS6 uses other sensors to measure load - primarily manifold air pressure, also throttle position, engine speed, temperature, etc.
If you think the filter change has brought this about, it could be you've missed one of the many connections on the filters. Crankcase breathing is particularly complicated, and you might be hitting the breather mode changeover off/on boost.
Nice top speed run! Can't be too much wrong.
Nick
c3nturi0n
Post by c3nturi0n » Wed Aug 14, 2019 3:00 pm
Nick
cheers Nick.
Any suggestions on how to diagnose so as to determine what's causing this "phenomenon" i have?
Car boosts fine past 3k revs... it's on that 2.2-2.5k where i notice that slight hesitation / almost shudder like feeling.
reason why i mentioned MAFs is that i had such manifestation in the past with large TDI Audi engines (A6 3.0 and A8 4.2) and it was cured with MAF replacement.
- H&R ARBs
Jim Haseltine
Post by Jim Haseltine » Wed Aug 14, 2019 3:54 pm
I'd take a look at the air pressure sensors. If the connections are ok take the sensors out of the inlet pipes and give them a spray of silicone free carb cleaner if they look to be oiled/mucked up. Shake them dry or lightly dab them with tissue.
c3nturi0n
Post by c3nturi0n » Wed Aug 14, 2019 6:38 pm
cheers Jim.
can you advise where they are located in the engine bay or point me to a right part number on the diagram please?
https://audi.7zap.com/en/rdw/audi+rs6+r ... 008-641/1/
- H&R ARBs
Jim Haseltine
Post by Jim Haseltine » Wed Aug 14, 2019 10:14 pm
Parts 39 on https://audi.7zap.com/en/rdw/audi+rs6+r ... 45-145050/
I'd suspect that you get the 'stutter' when you've got your foot down and not when you're at light/medium throttle? If so, chances are that it's a pressure sensor that's either dirty or has an iffy connection.
c3nturi0n
Post by c3nturi0n » Fri Aug 16, 2019 9:23 am
cheers Jim... that worked well.
Many thanks.
- H&R ARBs
c3nturi0n
Post by c3nturi0n » Thu Aug 22, 2019 11:17 pm
silicone / maf cleaner worked for so much... I did order set of new sensors which i fitted today.
Car seems much better but i still do experience that slight misfire like syndrome ~2200-2500 revs.
Again nothing odd or weird reported on VCDS.
any other hints or clues?
- H&R ARBs
Toady1
Post by Toady1 » Mon Aug 26, 2019 8:12 am
Have you removed the throttle bodies ever? May be an air leak on the gaskets?
c3nturi0n
Post by c3nturi0n » Mon Aug 26, 2019 9:01 am
Good point Toady1... i did recently replaced o rings under the oil cooler and T/bodies were moved as part of the job. I’ll take a look at it but doubt that thick piece of rubber has any leaks 😎.
- H&R ARBs
welwynnick
Post by welwynnick » Mon Aug 26, 2019 12:47 pm
Throttle body gaskets are important on cars that use mass air flow meters for load measurement, but where load is measured with manifold air pressure sensors, like the RS6, it's not critical.
Nick
Users browsing this forum: No registered users and 22 guests
