Windscreen wiper failure
2.7 V6 30v biturbo - 380 bhp
Desmo
Post by Desmo » Wed Jan 04, 2006 7:06 pm
My windscreen wipers have gone from slow to a grinding halt. Have been told by my local friendly Audi Approved Dealer it's probably a linkages / motor failure. About £380 to replace. Have searched previous posts and can see no indication that this is a typical RS4 problem. Anyone with experience or tips to offer before I bite the bullet?
simple1
RE: Windscreen wiper failure
Post by simple1 » Wed Jan 04, 2006 11:09 pm
certainly not one I ave heard of, and been around for the life of the cars.........
s4woody
Post by s4woody » Wed Jan 04, 2006 11:48 pm
i bet u were around when they fitted the 1st wiper system on the 1st horse and cart.. :lol: mr audi only had 1 ring and that was his teething ring... :kissmyrings: :redrs4: :lol:
simple1
Post by simple1 » Thu Jan 05, 2006 8:23 am
Think the company was called Auto Union when I first set out :bigwave:And Mr Audi was actually called Ferdinad Peache :biggrin3:
Jani
Post by Jani » Thu Jan 05, 2006 8:25 am
Same problem here. Seems common in newer Audis, supposedly it is the linkages that is the problem. It needs to be dismantled and lubricated -I'm told. If the motor has been burned, then that is needed as well.
philipwalker
Post by philipwalker » Thu Jan 05, 2006 9:47 am
Many of the early Passats, Audi 80s and 90s suffered with motor failures.
You may find the motor is common to most VAG cars, as suggested a strip, grease and replace the motor may be all thats needed. Timing the replacement motor needs some thought though!!
http://www.pwmotorsport.com
PW Motorsport
01437 563929
martinhans
Post by martinhans » Thu Jan 05, 2006 11:16 am
once when i was skint i had a knackered old rover 820 vitesse, the wiper linkage on that broke straight through, problem was it was raining cats and dogs at the time. i tried putting a bit of string on each wiper and pulling it from the drivers seat and that didnt work - in the end i got the long rubber coin mat off the dashboard and stuck it out of the drivers window and wiped it up and down the windscreen (seriously) - on the motorway.
probably not useful advice for you since RS4's don't have coin mats.
B7 RS4 Avant Sprint Blue/Black Recaros: Carbon Ceramic Brakes, Tech pack, Double Glazing, Solar Roof and Stuff
Sold
92 S8 D2 Ebony Black Pearl/Sable Grey
02 TT 3.2 DSG Avus Silver/Silver
01 RS4 B5 Avus Silver/Black
98 S8 D1 Jasper/Black
derdle
Post by derdle » Thu Jan 05, 2006 11:31 am
Continuing the theme of possible "workarounds" (martinhans).... why not use a magnetic fish tank glass cleaner - cost about 2 quid. That way you don't have to lean out of the window.
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin :biggrin3: If you dont "do it now" you never will.
SimonS4MTM
Post by SimonS4MTM » Thu Jan 05, 2006 12:16 pm
Mine did that a while back. Take off the arms and the robber boots from the point the arms attach and spray some WD40 on the pivots followed by some spray grease. That should sort it.
martinhans
Post by martinhans » Thu Jan 05, 2006 12:28 pm
" Take off the arms and the robber boots from the point the arms attach"
Sounds like something that should be done to audi dealers. I'm sure they all wear "robber" boots.
Sold
waitey1
Post by waitey1 » Thu Jan 05, 2006 2:51 pm
It happened to me last summer Bowes Moor (A66). Thought the motor had packed in. Took it to Bradford Audi they diagnosed seized spindle boxes and replaced wiper linkage under warranty. Motor seems fine. Part was in stock! indicating that it must be a common failure.
Part £63.91 Total bill £147.74 only warranty claim last year 01 RS4
docurley
Post by docurley » Thu Jan 05, 2006 6:31 pm
It will be the linkage that has sized.
Quite common on the face lift A4's
Had to do mine last year, got mine from a breakers then greased it up as my old one was beyond repair.
VST
Post by VST » Thu Jan 05, 2006 6:50 pm
Did mine last year also....
MTM RS4
pauliesans
I've just had the same thing
Post by pauliesans » Fri Jan 06, 2006 2:43 pm
My wipers have just done the identical thing. It ended up being the linkage, easily fixed by Caffyns in Brighton for £301. Blinking nuisance really...
docurley
RE: I
Post by docurley » Fri Jan 06, 2006 3:57 pm
£301!!!!
Cost me total £60 plus my time.
