RS6 C6 and RS6 C7 brake calipers interchangeable ?
5.0 V10 50v biturbo - 571 bhp
PPETKOV
Post by PPETKOV » Wed Jul 17, 2019 4:04 pm
Hello Gents, I'm trying to figure out if the brake calipers from RS6 C6 and RS6 C7 are compatible.
Based on my research over the internet it looks like that the brake calipers from RS6 C6 and RS6 C7 are pretty much equal.
The only visible difference is that the brake calipers for RS6 C7 are having balance weights.
So can someone confirm if those calipers are really interchangeable ?
Below are my findings
RS6 C6 OEM Part numbers
Brake caliper black left 4F0615107
Brake caliper black right 4F0615108
brake pad pins 4F0698269B
set pistons and gaskets 4F0698471A
RS6 C7 OEM Part numbers
Brake caliper black left 4G0615107D
Brake caliper black right 4G0615108D
For both calipers the brackets are with the same Brembo part number 20.9747.14
Also the Brembo part numbers for brake calipers are the same: 20.8834.01 (left) 20.8834.02 (right)
At least based on the information and pictures from here, here and here.
IanH755
Re: RS6 C6 and RS6 C7 brake calipers interchangeable ?
Post by IanH755 » Fri Jul 19, 2019 1:28 am
The calipers are the same but the C7 caliper mounting brackets (and C7 discs) have different offsets to the C6 so, while just the C7 caliper alone would physically fit C6 discs off the car, the caliper mounting bracket would have to be customised to allow it to fit the C6 with the correct offset for C6 discs when fitted.
Toady1
Post by Toady1 » Fri Jul 19, 2019 7:40 am
Can it be alterered with shims or would it mean machining some of the caliper mount away instead?
IanH755
Post by IanH755 » Sat Jul 20, 2019 5:09 pm
I can't remember, I think there was a thread in the C7 forum about it.
PPETKOV
Post by PPETKOV » Tue Jul 23, 2019 11:17 am
Thanks for you answer Ian.
Yes the disks are having different offest. Looks like that I missed to mention what's my goal.
So I'm trying to figure out if the brake calipers from RS6 C7 can fit on RS6 C6 with disks for RS6 C6.
According to photos and part numbers the brake calipers should fit ... but that's just my assumption.
Can someone tell if the distance between the center of holes of miunting brackets are the same for RS6 C6 and RS6 C7
George
Post by George » Thu Aug 01, 2019 4:43 pm
I may be able to measure the distance of the mounting holes next week, do i remember correct that they are alcon calipers with 420 mm disks?
if i get it right you have RS6 c6 calipers and disks and you want to fit them on RS6 c7?
IanH755
Post by IanH755 » Thu Aug 01, 2019 8:19 pm
Yeap the Ceramic setup is Alcon calipers with 420mm discs and the Steel setup is Brembo Calipers with 390mm discs.
PPETKOV
Post by PPETKOV » Sun Aug 04, 2019 10:25 am
@George I'm having A6 with 3.0TFSI therefore 347mm front disks ... and currently I'm trying to figure out if I can fit the calipers from RS6 C7 (the 6 pot Brembo).
As it looks like the RS6 C7 front brake setup can fit (including the disks) ... well it will be needed to use shims and longer bolts but that's not a big deal.
Also it will be needed to get wheelbearing housing from RS6 but luckily those are the same for VW Phaeton and Audi A8 D3 and can be found at pretty goodprices something like around 50 EUR per side.
p.s. Please excuse me for messing up with a standart A6 in the RS6 section.
