Charger build thread
Lukes3
Re: Charger build thread
Post by Lukes3 » Thu Feb 08, 2018 2:26 pm
DavidRS4 wrote:
Thu Feb 08, 2018 1:34 pm
Hope the paddle isn’t too much of an on/off feel
And me but its the only one i can find that is rated to take the extra power.
I know people say the oem one is ok to a point, but so far mine keeps getting hot if i give it the beans.
DavidRS4
Post by DavidRS4 » Thu Feb 08, 2018 5:55 pm
What about the JHM ones?
Lukes3
Post by Lukes3 » Thu Feb 08, 2018 8:32 pm
They have to work with there flywheel, im not changing the flywheel yet
Lukes3
Post by Lukes3 » Mon Mar 05, 2018 12:22 am
Update,
The sachs sintard paddle clutch with the sachs performance pressure plate has been fitted, only drove the car about a mile due to the weather but first thoughts are good, nice an easy on the foot if i didnt tell you it had a performance clutch you wouldn't of known. There is a slight bit of judder when pulling away but it hasnt even bedded in yet so we will see in a few mile.
DavidRS4
Post by DavidRS4 » Sat Mar 10, 2018 7:26 pm
Sounds promising.
andyg72
Post by andyg72 » Sun Oct 07, 2018 11:57 pm
Only just read this luke needs more pictures mate
Here’s mine trying to keep him behind :)
Lovely motor Image
Lukes3
Post by Lukes3 » Mon Oct 08, 2018 10:23 am
Cheers mate, not updated it in awhile.
Only thing done really is changed the aircon pump and new set of spark plugs.
Oh an put a pipe on the water tank to stop water goimg on everything in the engine bay. Was looking a mess
DavidRS4
Post by DavidRS4 » Thu Oct 11, 2018 6:19 am
How is the clutch?
Lukes3
Post by Lukes3 » Thu Oct 11, 2018 9:39 pm
How is the clutch?
It works great, no slipping at all, can launch the car hard an it will take it, just dont like a judder its got on soft pull off.
Lukes3
Post by Lukes3 » Fri Nov 23, 2018 6:40 pm
Update on this.
Had a on going issue with the air in take temp sensor since fitting this kit in march 2017, some times working some times not.
Freeze frame reading -40!?.
Had a word with mrc (doug) about this an they said at the time it wont be a problem with sensor because its a genuine part.
Checked wiring an all is good an done other checks aswell.
Anyway had enough last weekend an striped it down an pulled the “genuine sensor” out, turns out its not genuine!
In all fairness to MRC they didnt know this crap sensor as you will see in pictures was been supplied by TTS. It even had plastic on the terminals of the sensor!
Refitted with a bosch unit an all is well, no fault codes and silly -40 readings.
So just a thing to look out for with anyone else with a tts kit.
Lukes3
Post by Lukes3 » Sun May 26, 2019 7:23 am
New brakes fitted thanks to vagbremtechnic nice bit of kit these are, with ap racing rotors.
Also replaced prop-shaft centre bearing.
dhali
Post by dhali » Sun May 26, 2019 9:25 am
Excellent build thread .
Lukes3
Post by Lukes3 » Sat Aug 03, 2019 9:32 am
Little update
New things going! Write up soon
DavidRS4
Post by DavidRS4 » Tue Aug 20, 2019 5:35 am
It’ll be interesting to see if it makes a difference.
DavidRS4
Post by DavidRS4 » Tue Aug 27, 2019 11:53 am
Any updates?
Return to “Readers' Rides”
Users browsing this forum: No registered users and 6 guests
