2003 RS6 6SP Manual
jolio1994
2003 RS6 6SP Manual
Post by jolio1994 » Tue Jul 23, 2019 5:15 pm
Doing this for real now... Listed stateside
Hi all, 2003 Audi RS6 with 3 pedals that I've finally come to terms with selling, gotta move onto my next BCY venture... I purchased this RS6 from a long time friend and enthusiast down in Georgia and drove it up to New Jersey. It was leaking coolant from the bufkin pipe as well as weeping valve cover gaskets so I pulled the engine/trans a month after purchase.
All of the following were performed at 89,500 miles:
-Complete Timing Belt Kit and Coolant Flush
-Oil Change and Filter
-Valve Cover Gaskets
-Replaced Driverside Cam Chain Tensioner
-Bufkin Pipe replacement with new oil cooler seals.
-Both Front Wheel Bearings
As I was preparing to reinstall the engine I was considering beefing up the existing auto trans, but decided a manual conversion was the way to go. So I saddled up and bought an entire 2000 Audi A6 to serve as my donor. Parts list related to the conversion...
-01e Transmission with 131,xxx Miles, Syncros are Perfect!
-Transmission fluid flush with LiquiMoly 75w-90
-SteveKen Manual Conversion Kit. Included Flywheel, Starter, Adapter Plate, and all hardware.
-Ringer Racing Stage 4+ Clutch and Pressure Plate Combo. Rated at 850 ft-lbs.-New OEM Master and Slave Cylinder
-2 New Front Axles (Still have OEM Manual ones that need new boots).
-Stock Downpipes, Fully Gutted.
-Manual Tune by Blake Beadle. Car runs and dives as it would had the RS6 came with factory manual transmission.
I cannot stress how flawless the exterior and interior of this car is. Southern car its whole life until I drove it up in January. Then it sat inside for the remainder of Winter. It's never seen salt, there's no rust on it whatsoever. I have brand new Zimmerman Brake Rotors ready to go on ($1200), but between working full time and being a full time student, I just don't have anytime for the car other than driving it.
-The A/C squeals when started at idle, but if started while driving, even coming to a stop and back to idle, is fine. Serpentine belt and tensioner all both brand new, so not sure how or why, but something to consider.
-Clutch was never fully broken in so it does slip, but with that being said, it holds power perfectly fine and doesn't need to be addressed immediately. I was going to replace it this Winter, but if it sells it sells. Car still rips if applying to torque properly. Just kinda ready to move on in life. It's been priced accordingly.
$20,000 FIRM
Little Egg Harbor, NJ
Full walkaround/driving
[youtube]https://www.youtube.com/watch?v=F8i5zu3Usrk&feature=[/youtube]
Image20190510_075744 by Joel Francisco
Image20190510_075715 by Joel Francisco
Image20190530_074006 by Joel Francisco
Image20190530_074215 by Joel Francisco
Image20190530_073940 by Joel Francisco
Image20190530_073853 by Joel Francisco
Image20190616_175917 by Joel Francisco
Image20190616_180140 by Joel Francisco
Image20190616_180042 by Joel Francisco
Image20190616_180101 by Joel Francisco
Image20190616_180204 by Joel Francisco
Image20190616_180534 by Joel Francisco
ImageVideoCapture_20190704-030535 by Joel Francisco
Image20190222_161627 by Joel Francisco
Image20190330_233243 by Joel Francisco
Mark-RS
Re: 2003 RS6 6SP Manual
Post by Mark-RS » Tue Jul 23, 2019 5:24 pm
?? You've only had it a short while !
jolio1994
Post by jolio1994 » Tue Jul 23, 2019 5:52 pm
Yea, it was fun, but I bought a URS6 Avant.
Going to BCY/01E swap it
Weiß-sechs
Post by Weiß-sechs » Wed Jul 24, 2019 2:15 pm
So, you got the V8 urS6? Keep us updated on how you go on with the swap.
GLWS.
jolio1994
Post by jolio1994 » Sat Jul 27, 2019 4:27 am
GLWS.
It's not the plus, just the standard 2.2t
If I can move this RS6, the URS will get the full RS6 treatment with twin GT30's sticking out of the hood
Weiß-sechs
Post by Weiß-sechs » Sat Jul 27, 2019 1:42 pm
Right...
Shame to swap out the AAN though, you can do a LOT with them, especially in the US (034 Motorsport etc.)
jolio1994
Post by jolio1994 » Sat Jul 27, 2019 1:53 pm
Right...
034, EFI, and IROZ have all pretty much dropped all AAN/3B aftermarket parts such as headers and intake manifolds, downpipes and exhaust... I can do that all regardless, but I think a S6 + + would be pretty dope, seeing as we dont have any in the states. An unconventional swap non the less.
Weiß-sechs
Post by Weiß-sechs » Sat Jul 27, 2019 5:48 pm
That's a pretty spicy project, keep us posted. I'll be checking out your You Tube channel with anticipation :thumbs:
Users browsing this forum: RS4AvantB7 and 83 guests
