Shoppinit wrote: ↑Sat Jul 13, 2019 8:32 am
FFS. It's getting ridiculous!
can't agree more facepalm..
Remind me, because a lot of water has gone under this bridge:
- Did you clean the PCV system out completely?
yes
- Did you replace the PCV valves?
yes
- Did you put the old wastegates back on?
not yet, will do shortly
- Did you check the N75 pipes for leaks?
yes
Can you do a pressure test on the wastegates? Make sure they both start to open at the same pressure? Should be about 0.5 bar. I mean the whole wastegate, not just the actuator.
yes I suppose I can control whether they are calibrated the same on both sides
Can you check that both wastegates open freely without sticking?
will check
How much discrepancy are we talking about now?
seems worse than ever
Couldn't find the time for a proper test but at idle it was like 2,5g/s left bank versus 4,5g/s right bank..
Can you do a new log and post it up in csv format?
sure, will do Log the following:
- A half throttle 3rd gear (or 4th if not impracticable) run from 1500 to 6000 rpm
- A full throttle run as above
- A constant speed run at 2600-2700 rpm
Log groups 002, 117 and 118. Or the MAFs, N75 duty cycle and boost (specified and achieved) if you log items individually. In turbo mode.
Once you've eliminated the leaks, PCV, N75, N249, DV and all the other vac systems, there's not much left other than turbo imbalance or exhaust obstruction to explain this.
yes I ve also reach the same conclusion about turbos
I wonder if there's a way of checking the pressure from the individual turbos. You could check one turbo at the N75, but the other one would be more problematic. Not sure if there's anywhere you can attached a pressure gauge easily. There might be a blanking plate / plug. Or I guess you could check the pressure at the N75 and compare it to the total pressure at the inlet manifold. I'm not convinced that it's as simple as Total pressure = Pressure1 + Pressure2 but might give some indications.
I'm wondering if a boost side leak could cause this issue. Seems unlikely. Plus you're on Wagners, aren't you?
yes I am equipped with Waggies
