air filters
huntersmob
air filters
my itg filters are falling apart has anyone use the bmc filters are they any good ?
huntersmob
Re: air filters
ive ordered a set so hope they ok @90 notes
Re: air filters
The ITG ones have been known to dry out and get brittle with the constant heat-cycling of the engine bay, making it easy for the engine suction to start to pull them to bits.
You're supposed to clean and lube them once a year as per this thread - viewtopic.php?f=47&t=126299 - and when I last checked MRC had swapped to BMC but these again need an annual "service" too.
Re: air filters
my ITG filters lasted 3 years, got BMC ones now. Seem much better made.
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Belmont SRi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
1st car Datsun 120 FII Lime green....yeah
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
Re: air filters
ECP / carparts4less are doing a good deal on both.
Any thoughts re what to opt for?
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
- H&R ARBs
Jim Haseltine
Re: air filters
BMC. Their construction is similar to K&N being a fabric encased in mesh rather than the foam used by ITG.
The yearly clean & oil is a bit time consuming so I pick a weekend when I'm not going to need to use the car. I suppose a sensible thing would be to have two sets - swap out the dirty ones and then service them at your leisure ready for the next change.
Re: air filters
cheers Jim.Jim Haseltine wrote: ↑Fri Jun 07, 2019 12:37 pmBMC. Their construction is similar to K&N being a fabric encased in mesh rather than the foam used by ITG.
BMC it is then
- H&R ARBs
- H&R ARBs
welwynnick
Re: air filters
Can anyone tell me the dimensions of the RS6 air filters please?
Thanks, Nick
Thanks, Nick
Jim Haseltine
Re: air filters
Not easy to describe. The filter sections are parallelograms approx 175x160 canted by approx 20mm on the 160 side. Right filter slopes to the right side of the car, left slopes to the left.
- Weiß-sechs
- 5th Gear
- Location: Everywhere & nowhere baby, that's where I'm at...
Re: air filters
Spot on description. That's exactly what arrived at my local ECP after I'd ordered a set of BMC on special offer....for my C5. ClownsJim Haseltine wrote: ↑Sat Jun 08, 2019 12:57 pmNot easy to describe. The filter sections are parallelograms approx 175x160 canted by approx 20mm on the 160 side. Right filter slopes to the right side of the car, left slopes to the left.
welwynnick
Re: air filters
Thanks guys. Are the filters about 25/30mm deep?
I've been surveying air filter sizes on a range of cars with V engines and filters on both sides to find which has the biggest filters (then I want to see if any of them can be made to fit the RS6!).
Nick
Nick
Re: air filters
hi Nick,welwynnick wrote: ↑Sun Jun 09, 2019 9:25 pmThanks guys. Are the filters about 25/30mm deep?
Nick
both BMC and ITG performance filters are compatible with C6's.
- H&R ARBs
- H&R ARBs
Re: air filters
I luv the clean and service once a year; I wish..... mines been serviced once this year and its now due again. I just keep telling myself it was made to be driven....IanH755 wrote: ↑Wed Oct 24, 2018 9:22 pmThe ITG ones have been known to dry out and get brittle with the constant heat-cycling of the engine bay, making it easy for the engine suction to start to pull them to bits.
Re: air filters
Carparts4less are doing a good deal on both BMCs and ITGs... lead time is couple weeks and if you are not in a hurry, it's worth considering!
ps. i ordered BMC as per advise on forum experts (and to replace my dated MRC ones).
- H&R ARBs
- H&R ARBs
Re: air filters
Here Euro Car Parts
Part number 909440341 BMC Performance Air Filter Audi RS6 5.0 2008
Users browsing this forum: Google Adsense [Bot] and 27 guests
