Guys looking to purchase a rs6 with ceramics fitted
Wanted to know if the wheels I have sitting in my garage will for the rs6
Anyone here can tell me what the overall diameter is from edge to edge on discs/calipers?
So I can see if the wheels will fit over the brakes
I’ve measured up the wheel and it measures a just under 450mm
Rs6 with ceramics (wheels size diameter)
welwynnick
Re: Rs6 with ceramics (wheels size diameter)
The front discs measure 420mm, so that leaves just 15mm for the caliper, which seems a bit slim.
What diameter, width and offset are the wheels?
Nick
Nick
20” Rohana alloys
11j
Will have to check offset
I don’t see the calipers being more than 30mm
If the discs are 420mm
Let’s say calipers are 20mm
Still 10mm left to play
I think it should be ok
Unless anyone else here has the ceramic brakes option and can measure edge to edge for me just to be
11j
Depending on wheel options the standard C6 offset for the 9.5J 20" rims is ET36 for both steel and ceramic disc versions; for the 9J 20" its ET38
Disc comparison
Disc comparison
Users browsing this forum: hartley1967 and 92 guests
