Standard steel discs and pads.. How long should they last?
Re: Standard steel discs and pads.. How long should they last?
Seems fair Mike.
I guess I'm just feeling bruised after the failure to fix the grabbing brakes, the 7 buckled wheels, 4 new summers, 4 new winters.....!!
Anyway Bicester Scramble on Sunday if anyone is there?
Sent from my SM-G935F using Tapatalk
RS6 Performance Edition - Daytona Grey - 2016
Golf R - Deep Black - 5 door, DSG - 2016
X5 40d - Sapphire Black, 7 seats - 2011
VFR800F - Silver - 1997. In many years, only miles is to and from the MOT centre
My car is at 26k and all discs/pads are fine (sadly as I have Audi maintenance paying for them until December so would prefer to have them swapped before then, so far they incurred zero cost).
They do squeak unless you go out and thrash it with hard braking once a month; first world problems and all that.
Current Audis: Audi RS6 PE, Audi RS3 Sportback
Ex-Audis: RS4 B8, RS6 C6, A6 2.7Q, A4 2.8Q
i'm on original discs and pads all round @ 34k miles (a lot of mway) and I have a bit of squeaking now at times. In for service soon so they will tell me what % worn mine are - car is 2017 PE.
Steve
Steve
A timely post for me. Mine have just come back as 98%worn. Can’t see it myself. Discs are also marked as urgent. I’m at 42k and (including the originals ) this will be my 3rd set of discs and pads. Harsh driving? I get 16-18k out of a set of tyres so I can’t be that harsh.
Maybe I should consider myself lucky!!SimonR wrote:A timely post for me. Mine have just come back as 98%worn. Can’t see it myself. Discs are also marked as urgent. I’m at 42k and (including the originals ) this will be my 3rd set of discs and pads. Harsh driving? I get 16-18k out of a set of tyres so I can’t be that harsh.
Sounds like hard driving or long periods of downtime.
All OEM?
tonybrown5
Out of interest why are the OEM discs and is so expensive? Are the better after market options available and presumably they are not rocket science to fit?
brab wrote:Being that for the price of 1 ceramics you can roughly get 5 sets of standard discs and pads, unless you track the car it's really not cost effective.
I’ll not need to change discs at all, if I do it’ll be once in 200k miles. Pads maybe at 100k miles. Some are getting through 5 sets in less than 100k miles
So where is the best place to buy a full set of ‘ramics (callipers, disks, pads)gsc wrote: ↑Sat May 04, 2019 10:57 pmbrab wrote:Being that for the price of 1 ceramics you can roughly get 5 sets of standard discs and pads, unless you track the car it's really not cost effective.
I had my RS4 for 9.5 years and can see myself keeping this one for this long, so might be worth it! Although I only changed front discs and pads once on the RS4 and it still had the original rear disks and pads when sold! (79k).
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
Previous:
You're looking at about 10 to 12k for a set off ebay.
My car is on 28k, it's on it's second set of disks and pads, and they are far from warn but have developed a mild but annoying warp. When I change again I'll try and get an AP or higher grade disk.
The front disks on my 14 plate RS4 were exactly the same, mild warp long before they reached the end of life.
My personal experience / opinion is that OEM are designed to fail, as a tidy revenue stream for Audi.
Unlikely they are warped. More likely you have pad deposits from not using them heavily enough.MikeBirt wrote: ↑Mon May 06, 2019 9:09 pmMy car is on 28k, it's on it's second set of disks and pads, and they are far from warn but have developed a mild but annoying warp. When I change again I'll try and get an AP or higher grade disk.
That's funny.MikeFish wrote: ↑Tue May 07, 2019 8:26 amUnlikely they are warped. More likely you have pad deposits from not using them heavily enough.MikeBirt wrote: ↑Mon May 06, 2019 9:09 pmMy car is on 28k, it's on it's second set of disks and pads, and they are far from warn but have developed a mild but annoying warp. When I change again I'll try and get an AP or higher grade disk.
Did 6 laps of a track day at Croft a six weeks ago, and they were on fire - never seen brakes smoke like that (yes traction control was off) they were fine after that for a while and now as soon as there is any heat in them they warp. When cold, straight a an arrow.
I have had a number of setups on different vehicles that have done this. Just poor quality disks in my opinion.
The face of all 4 disks is as clean as you could ever hope for...
15k miles here, driven properly
Users browsing this forum: Bing [Bot] and 28 guests
