Hold on, blow hot air into the inlet and use your magic thermal camera!
Yes, thanks for the encouragement and the good vibes again!
Good tricks! However none of the above would do I'm afraid as there is some sort of 'valve' effect, like the leak doesn't appear until air reaches a certain pressure (0.2 bar or something?), so I guess the smoker will loose its lungs sooner than expected if he needs to hold that pressure whilst sending enough smoke in the system..Shoppinit wrote: ↑Fri May 03, 2019 4:28 pmIf you try to blow into it can you push any air through with your mouth? If so, find a smoker and get them to blow some smoke into the system. Not sure if you'll find a smoker in Paris though.
That's a good one too!
Count on it! LOLOL
Maybe you can find a smoker who's good at blowing in rue Saint Denis?
