need help on type of spark plugs
I am from the philippines and over here i am the only one rs4. now here is the problem i need to charge my plugs and they only have in the delaer this plugs 101000063AA i know this plugs are used in the s4 can i use this on my rs4 its a 2001 the right plugs i need is 101000063AC but i need to use the car and there is no other plugs here but the one for the s4 can i use it has any one used this plugs hope some one can give me insite to my problem in advance thanks a million for the help and info
RE: need help on type of spark plugs
Sorry I don't know, but you could try contacting NGK or any other plug manufacturer to see who makes a plug for the RS4. I'll bet they're cheaper!
Let us know how you get
- SimonS4MTM
- Top Gear
PFR7Q is the NGK number i believe
nogaroHIRO
Hi,
I recommend DENSO Iridium power IK22 for Audi RS4 with no modifications.
link for the spark plugs matching for Audi RS4 by DENSO:
http://www.denso.co.jp/cgi-bin/plug/4wp ... 8%A1%BA%F7+
DENSO global site:
http://www.globaldenso.com/en/
nogarohiro
DENSO global site:
nogarohiro
nogaroHIRO
hataw,
Standard plugs are good for standard usage.
If you drive the car keeping the engine revolution higher than standard, you should select higher heat range (colder type) spark plugs.
If you drive the car gently always in lower engine revolution range, you can use lower heat range (hotter type) spark plugs.
My RS4 has re-mapped ECU and has around 440ps crankshaft output (It means more fuel burns and engine temperature tends to be higher than standard),
so I selected IK24, one rank colder than recommended IK22. Both plugs were trouble-free in my RS4, but I have no experience with IK20 in my car.
I suppose that you can use IK20 if you do not use the engine keeping revolution high for long period, but RS4 is not such a car as you know.
If I had stock RS4, I would not select IK20 but order IK22 and wait.
You can learn some on spark plugs here: http://www.globaldenso.com/PLUG/basic_k ... index.html
The trouble shooting page is good with many pics. Learn and select yourself.
nogarohiro
nogarohiro
nogarohiro
thank you so much for the info. I better get the ik22 or if they have it the ik24 i will just have to order it from hong kong as here in the philippines they dont have those type of plug only one available here is the ik20 but any way great to realy have this forum to get help from fellow rs4 lovers any guy a merry cristmas to you all from the philippines
itaplikeabiatch
itaplikeabiatch
nogaroHIRO
well...
There are many RS4s in Japan. Some are for sale now.
link for RS4s for sale... two reds, black, silver(no pic, now printing), and nogaro blue
http://www.carsensorlab.net/usedcar/s.p ... ax=&color=
nogarohiro
nogarohiro
itaplikeabiatch
Users browsing this forum: No registered users and 62 guests
