2014 RS6 C7 Cutting out on start up.
dannyuk
Re: 2014 RS6 C7 Cutting out on start up.
Post by dannyuk » Wed Apr 17, 2019 6:35 pm
Thanks Mike - is this what you have ?
https://rover.ebay.com/rover/0/0/0?mpre ... 2550680716
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Markwes
Post by Markwes » Wed Apr 17, 2019 6:40 pm
I’m also running the Milltek valve delete modules with the standard sports exhaust with centre res delete, still getting false starts
I was advised by Audi to change the spark plugs as they were well overdue but I’m still getting the same issue after the plugs have been changed.
If it was anything to do with the exhaust valves being disconnected I would imagine a lot more owners would be experiencing the same issue.
Audi RS6 c7 2014| Estoril Blue | Dynamic pack | Sports Exhaust.
dannyuk
Post by dannyuk » Wed Apr 17, 2019 6:42 pm
Yeah I was thinking that - out of interest have they looked at your fuel pump at all?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
dannyuk
Post by dannyuk » Wed Apr 17, 2019 6:44 pm
Also on a false start do you just put your foot on accelerator and it fires ?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Markwes
Post by Markwes » Wed Apr 17, 2019 6:50 pm
No, Audi just advised me to have the spark plugs changed as they were so far overdue. I’ll be taking it back in when I have the time.
Markwes
Post by Markwes » Wed Apr 17, 2019 6:53 pm
dannya32 wrote:Also on a false start do you just put your foot on accelerator and it fires ?
Yes, give it a bit of throttle input and it fires straight up. Can be a bit lumpy for 1 or 2 seconds but then it’s fine. Only had it happen once in the past 2 weeks, doesn’t seem to be getting any worse.
dannyuk
Post by dannyuk » Wed Apr 17, 2019 6:56 pm
Yeah exactly the same - sometimes can go 3 weeks+ no issues.
It does seem to be worse when I have done a short ish drive leave the car for 4 hours then start it up.
Would be interesting to see if anyone had had this issues with the stock exhaust
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Post by MikeFish » Wed Apr 17, 2019 7:09 pm
Yes.
Gniwog
Post by Gniwog » Mon Jan 06, 2020 11:51 am
Think mine is starting to do this, anybody get to the bottom of it??
dannyuk
Post by dannyuk » Mon Jan 06, 2020 11:52 am
Do you have an after market exhaust on it?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Gniwog
Post by Gniwog » Mon Jan 06, 2020 6:05 pm
No, all standard. Seems to happen when car has been run upto temp then left for maybe an hour. Car starts up like normal with the throttle blip then just dies. Takes a few restarts to get it going again then it's fine.
dannyuk
Post by dannyuk » Mon Jan 06, 2020 6:17 pm
Yes exactly the same as mine - strangely I thought it was down to the miktec exhaust I had. Is yours under warranty?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Tadass910
Post by Tadass910 » Mon Jan 06, 2020 6:18 pm
Does it make any sense if exhaust aftermarket or not?
dannyuk
Post by dannyuk » Mon Jan 06, 2020 7:09 pm
A while back one of the users stated it was due to the aftermarket exhaust, I never asked why.
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Markwes
Post by Markwes » Mon Jan 06, 2020 9:54 pm
I’ve had this same issue since buying the car back in 2018.
I’m running milltek valve delete modules and resonator delete on the standard sports exhaust so can’t be anything aftermarket exhaust related
Every time it happens to me the car has always been sitting for a few hours after a decent drive, when it does fire back up it will run slightly lumpy for a few seconds then it’s fine.
Users browsing this forum: Google Adsense [Bot] and 105 guests
