PCV valve
Re: PCV valve
Out of curiosity, how have you diagnosed this ? Normally the visible signs are excessive black smoke from the exhaust...
Re: PCV valve
It’s a whistle that comes on tick over, or coasting below 2k. There are 2 valves, one is physically pulling a vacuum through the breather hole suggesting the diaphragm is gone. Cars not pulling oil through like you say, I think this is because there are two on the b8, where there was only 1 on the b7. Had to go to my mechanic in the end as I gave up trying to find part numbers, £115 for the part alone.
Re: PCV valve
Did you get this sorted in the end?noddy wrote:It’s a whistle that comes on tick over, or coasting below 2k. There are 2 valves, one is physically pulling a vacuum through the breather hole suggesting the diaphragm is gone. Cars not pulling oil through like you say, I think this is because there are two on the b8, where there was only 1 on the b7. Had to go to my mechanic in the end as I gave up trying to find part numbers, £115 for the part alone.
Re: PCV valve
Yep, local specialist sourced it. £180 fitted. Diaphragm was shot.
Re: PCV valve
Which side had gone? Where did you spruce part from..noddy wrote:Yep, local specialist sourced it. £180 fitted. Diaphragm was shot.
Very quick fix (even I can do it)
Re: PCV valve
Right hand side, specialist got it so no idea. Defo a diy job, vat and labour always bumps up the price.
Re: PCV valve
Cool, that’s the one I’m going for....
JA
JA
Re: PCV valve
What’s your symptoms?
PCV valve
This loud winning noise,
Hi all,
This noise appeared yesterday?
It appears to happen when your NOT accelerating!
When you accelerate it appears to stop.
Happens at tick over
However if I unplug right hand side one (as you face the engine) it’s stops
Hi all,
Re: PCV valve
If you unscrew the oil cap does it stop? if yes, you need the part.
Re: PCV valve
I’ve pulled off the plug from engine side & it stops, similar to removing the cap?
Re: PCV valve
Yep, it breaks the vacuum
Re: PCV valve
Diagnosis complete lol
Will source item on Monday.. thanks again
Users browsing this forum: Bing [Bot] and 416 guests
