Jas
Rear washer not working-f/p/footwelll damp?
UrielsMachine
Noticed the rear washer wasn’t working after l had purchased the RS a few weeks ago and got home. Have been working away a lot and decided to investigate tonight...found that the front passenger footwell carpet is slightly damp. Is this connected? Bust hose under carpet?. Will be ringing the garage l bought it from tomorrow
Jas
Jas
718 Cayman S - Manual box, PASM, Sport Chrono… it’s a joy.
RS6 c7 - a beast but now gone.
RS4 b5 - wish l’d kept it…
Re: Rear washer not working-f/p/footwelll damp?
Don’t suppose you have a Pan sun roof by any chance?!
Audi RS6 c7 2014| Estoril Blue | Dynamic pack | Sports Exhaust.
I'm guessing the layout is the same as the old C5. There's a joint in the pipe somewhere near the Pax door - on the C5 you simply took up the door trim and could access it quite easily.
Surprised they haven't fixed it given that it's an obvious design weakness!
No connection the hose wouldn't be able to leak internal . Really common for the jet nosel to corrode and fail will be a £4 fix at Audi to change out when it's in .
Pass footwell, you are the third person to mention this in as many months . Theres a few posts on this of late
. Get straight on to them its a major design fault .
2017 C7 RS6 PE Nardo
2014 911 991 C4S PDK White
2013 M6 Cab Blk
2012 911 997 MK2 PDK Silver
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
UrielsMachine
Right. Yep l have the pan roof. Door trim. What’s that. Thought the hose would have ran through the footwell. What’s the design fault with the passenger footwell?
All replies most appreciated. I’ve had previous experience with water in Audi footwells which has fried the electrics so l need to get to the bottom of this ASAP.
Cheers lads.
Jas
Cheers lads.
Jas
Check this recent post by Johny on footwell leak (DS)
viewtopic.php?f=76&t=131367
As your car is just purchased recently the dealer would have obligation to sort this out for you .
Another ;
viewtopic.php?f=76&t=131256
viewtopic.php?f=76&t=131162&p=906919&hi ... ll#p906919
Another ;
2013 M6 Cab Blk
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
UrielsMachine
Cheers Anth.
Jas
Jas
