Michelin Pilot Sport 4S 295 30 21,anyone fitted ?
uplandsway
Post by uplandsway » Mon Mar 18, 2019 3:51 am
Morning guys,
I`m gonna require tyres very shortly and was going to just bite the bullet and order for my upcoming garage time.
Has anyone fitted the Michy Pilot Sport 4S in 295 30 21 sizing as opposed to the OEM 285 30 21 and if so how is the fitment ?
My car is set up on KW Adjustable Suspension with Vossen Alloys 21X10.5 ET25, I dont run wheel spacers as the alloys pretty much sit where I want them.
Appreciate any thoughts or feedback.
Thanks!
Cheers,
Stevie F
2016 C7.5 RS6 Performance
Daveperc
Re: Michelin Pilot Sport 4S 295 30 21,anyone fitted ?
Post by Daveperc » Mon Mar 18, 2019 7:38 am
Yes, fitted them several months back - there's a post on here somewhere!
I have OEM wheels so I added a 5mm spacer so the inner face is where it was before and the outer face is +10mm so it fills the arches nicely.
VERY please with grip levels especially in the wet just as I was on my C5 beast - the improvement is noticeable.
Reading on the speedo is now actually closer to the reading by GPS.
Fit and enjoy!
Dave
uplandsway
Post by uplandsway » Sun Mar 24, 2019 4:08 am
Anyone else fitted the MPS4S in 295 30 21 sizing then ??
Cheers,
Stevie F
brab
Post by brab » Mon Mar 25, 2019 8:42 am
What does the speedo reading have to do with the tire width?
Here's the pic uplandsway, that Dave was talking about.
Daveperc
Post by Daveperc » Mon Mar 25, 2019 9:22 am
The depth of a tyre , in this case 30, is a percentage of the width. As the wheel size is fixed, if you increase the width and keep the depth % the same, you have a bigger rolling radius. If the radius is bigger, then the circumference will be bigger too, so the tyre will travel further for each revolution of the wheel, ie it will indicate slightly lower speed on the speedo.
Hope that helps! There is a website somewhere which will give you the direct comparison between different tyre sizes.
Dave
Markp
Post by Markp » Mon Mar 25, 2019 10:33 am
Rolling circumference is 20mm bigger with 295 tyre - due to deeper tyre wall (30% of 295 rather than 30% of 285) meaning the speedo will read 0.84% less at same speed. Tiny difference.
Markp
Post by Markp » Mon Mar 25, 2019 10:35 am
Dave
https://www.willtheyfit.com/index.php?w ... offset2=20
uplandsway
Post by uplandsway » Mon Mar 25, 2019 6:27 pm
Hi
I’ve not risked it as I don’t run spacers due to wheel offsets 21x10.5 et25 so have played it safe with MPSS 285 30 21
Cheers,
Stevie F
chandler99
Post by chandler99 » Tue Mar 26, 2019 1:40 pm
Hi
I’ve not risked it as I don’t run spacers due to wheel offsets 21x10.5 et25 so have played it safe with MPSS 285 30 21 Image
How do you find them? Fed of of the conti's so v tempted.
Daveperc
Post by Daveperc » Tue Mar 26, 2019 1:45 pm
There is a world of difference between the MPSS and 4S - I ran both on my C5 and the 4s was soooo much better!
Bite the bullet and get some - you won't regret it! :boots:
uplandsway
Post by uplandsway » Tue Mar 26, 2019 4:55 pm
Daveperc wrote:There is a world of difference between the MPSS and 4S - I ran both on my C5 and the $s was soooo much better!
As much as I’d like to fit the MPS4S in 295 flavour I don’t think it’d work with my set up so stayed safe with the MPSS in 285
Cheers,
Stevie F
uplandsway
Post by uplandsway » Tue Mar 26, 2019 4:56 pm
chandler99 wrote:
Hi
Contis have been fine, no issues whatsoever just fancied the michys
Will report back once fitted over weekend
Cheers,
Stevie F
Post by MikeFish » Tue Mar 26, 2019 5:22 pm
Plenty of space there Stevie boy.
uplandsway
Post by uplandsway » Tue Mar 26, 2019 5:24 pm
MikeFish wrote:Plenty of space there Stevie boy.
You reckon mike ?..
Even on fronts with my vossens ?
I got good deal on the MPSS anyhow and probs too late to cancel and order the MPS4S Image
Cheers,
Stevie F
HPsauce
Post by HPsauce » Tue Mar 26, 2019 7:03 pm
I didn't know they'd started making the MPS4S in 21s, maximum was 20" for quite a while initially.
Very pleased with them on my S8 for the last couple of years; had MPSS before which were great but MPS4S are even better all round.
Users browsing this forum: Google [Bot] and 101 guests
