Fuel Pump Noise !!!
2.7 V6 30v biturbo - 380 bhp
prof
Fuel Pump Noise !!!
Post by prof » Thu Dec 22, 2005 2:53 pm
should the fuel pump on my RS4 be so audible ???
It's not making any odd noises, it's just very audible when you are outside the car and also in the car when you turn off the radio.
Haven't heard another RS running, so I don't know if this is normal or not.
any thoughts ????
cheers,
dodgydave
RE: Fuel Pump Noise !!!
Post by dodgydave » Thu Dec 22, 2005 4:08 pm
Mine is quite loud too. Wouldn't worry too much about it.
Never enough...
bjacks
Post by bjacks » Thu Dec 22, 2005 4:20 pm
Some are louder than others, even more so when they are sucking the tank dry :D
Ben
prof
Post by prof » Thu Dec 22, 2005 6:15 pm
thanks for that.
ChrisG
Post by ChrisG » Fri Dec 23, 2005 2:44 pm
Her 1.8T has spent the summer months with a very noisy wining pump, but it is now quiet again. I'm sure it is coincidence but it seem to start getting quieter about the same time I switched over to Tesco's 99 octane. :?
Ben-- How is fatherhood? !!!!
simple1
Post by simple1 » Fri Dec 23, 2005 4:15 pm
Noisy pumps are usually a sign of impending failure, although they carry on pumping for a quite a while after they become noisy. Noise usually = loss of fuel pressure, certainly in the older Audis so be careful and get it checked out. Dont want to run it lean and cook something else.
bjacks
Post by bjacks » Fri Dec 23, 2005 9:01 pm
Fatherhood knackering Chris :D
Not sure whether it being noisey means it will fail, I remember hearing JohnRS4's pump really audibly, but mine was much more quiet. I doubt the ECU would let the car be starved of fuel, they have pressure regulators and alike.
All the best
Ben
simple1
Post by simple1 » Sat Dec 24, 2005 8:32 am
Johnrs4 was running twin pumps, and the second was installed without rubber mountings........ the ECU cant regulate the pressure from the pump, if the delivery pressures is wrong, rest assured it will cause problems, been there, done it and got the invoices to prove it.
Fastlane
Post by Fastlane » Sat Jan 14, 2006 1:08 am
I had mine replaced last summer (stuck in the midle of nowhere waiting 1 week for a new one) and the new pump makes more noise than the old one....
01 RS4 MTM stage 2, 04 Dodge Durango
*05 BMW 520 *01 S3 Dahlback stage 2 *00 S8 tipr *01 M5 stage 2 *98 S8 6sp *96 M3 Cab Individual + 95 750ia *93 VW vr6 *93 M5 touring
PhilT
RS246.com
Post by PhilT » Sun Jan 15, 2006 10:26 am
Had mine replaced last year too.
Brooner
Post by Brooner » Sun Jan 15, 2006 2:03 pm
Had mine replaced about 2 years after getting the car not really loud but enough to get iritating much better now and no problems almost three years on
