RS6 C7 Brake Pads - Front
RafaelPinaF
Hi guys,
I am from Brazil and looking for a set of front brake pads with sensor for my 2014 RS6 Avant and it has ceramic disc. Do you know the part-number from Audi (OEM part) or from Brembo?
The VIN number is: WUA82C4G9EN903492
Thank you
Thank you
Re: RS6 C7 Brake Pads - Front
Just been looking myself and after a lot of research I found out it is P 50 127 if you search around you can find them at a pretty reasonable price
Just got my Brembo front pads through, these are supposed to be the OEM pads according to the master tech who gave me the part number, got them from a supplier in Germany through eBay (yes they are genuine) for just under £80 and was delivered in 3 days by DHL
Can’t believe how big they are
- Toffeebananas
- 1st Gear
That’s a good price! You got a link for that please? Do they come with wear sensors?LeeRS6 wrote: ↑Fri Mar 08, 2019 11:46 amJust got my Brembo front pads through, these are supposed to be the OEM pads according to the master tech who gave me the part number, got them from a supplier in Germany through eBay (yes they are genuine) for just under £80 and was delivered in 3 days by DHL
Yes comes with 2 sensor leads same as the rear ones for some reason
https://rover.ebay.com/rover/0/0/0?mpre ... 2795496150
- Toffeebananas
- 1st Gear
Thanks, that good price. So far I have ordered Hawk pads. They arrived and didn’t have wear sensors. I have then ordered some TRW pads. They were meant to arrive Thursday/Friday and have still not arrived! I may order these if the TRW don’t turn up soon!
- Toffeebananas
- 1st Gear
That eBay seller has put them up by nearly an extra £100!
Good job I got in quick!
Haha it looks like we had a result
Thanks for the info, two quick questions:LeeRS6 wrote: ↑Fri Mar 08, 2019 11:46 amJust got my Brembo front pads through, these are supposed to be the OEM pads according to the master tech who gave me the part number, got them from a supplier in Germany through eBay (yes they are genuine) for just under £80 and was delivered in 3 days by DHL
1. Will these work with non-ceramic brakes?
2. Are the pads the same for the rear?
1. Nonooreaga wrote: ↑Sat Mar 23, 2019 12:19 pmThanks for the info, two quick questions:LeeRS6 wrote: ↑Fri Mar 08, 2019 11:46 amJust got my Brembo front pads through, these are supposed to be the OEM pads according to the master tech who gave me the part number, got them from a supplier in Germany through eBay (yes they are genuine) for just under £80 and was delivered in 3 days by DHL
2. No, but are what pads the same as the rear? Are you asking if the front pads are the same as the rear pads? Or if the rear pads for ceramics are the same as rear pads for the steels? Either way the answer is no.
- Toffeebananas
- 1st Gear
Mike, question 1. These are for non ceramic brakes?!? Should be a yes?MikeFish wrote: ↑Sat Mar 23, 2019 12:46 pm1. Nonooreaga wrote: ↑Sat Mar 23, 2019 12:19 pmThanks for the info, two quick questions:LeeRS6 wrote: ↑Fri Mar 08, 2019 11:46 amJust got my Brembo front pads through, these are supposed to be the OEM pads according to the master tech who gave me the part number, got them from a supplier in Germany through eBay (yes they are genuine) for just under £80 and was delivered in 3 days by DHL
The first post asked for brake pads for his ceramic brakes.
- Toffeebananas
- 1st Gear
So are the pads discussed and linked above for steel or ceramic brakes?
Users browsing this forum: Google [Bot] and 138 guests
