Something i noticed is that on hard-ish braking, his brake lights were "flashing" which i found really interesting , both functionally and aesthetically.
Hence the question - is this something that could be added or programmed to C6?
Thx Sam... i will give it a go.Surrey Sam wrote: ↑Wed Mar 20, 2019 6:48 pmI've done it for the B8 and just checked the RossTech wiki for the C6, where it looks like you can.
http://wiki.ross-tech.com/wiki/index.ph ... tem#Coding
Good pointStiggles wrote: ↑Sat Mar 23, 2019 3:31 pmI believe it's triggered by braking force, ie its to let cars following you know that you've had to slow down at an increased rate, I personally wouldn't like it installed as can you imagine seeing a police car while being naughty, hitting the brakes and the hazards going off, they'd pull a u turn and come after you in an instant lmao
Unfortunately I'd have no idea how to enable it, I have seen it on other cars and it's been triggered in our Merc trucks occasionally when hammering the brake.c3nturi0n wrote: ↑Sat Jun 22, 2019 9:00 pmGood pointStiggles wrote: ↑Sat Mar 23, 2019 3:31 pmI believe it's triggered by braking force, ie its to let cars following you know that you've had to slow down at an increased rate, I personally wouldn't like it installed as can you imagine seeing a police car while being naughty, hitting the brakes and the hazards going off, they'd pull a u turn and come after you in an instant lmao.
Here is what i’ve done... when i hit Test it does not yield the outcome desired.
Any hints?
Users browsing this forum: No registered users and 36 guests
