I have just bought a full set of black badges (front/rear rings and front/rear RS4 badge) from Audi for my B8 RS4. With a bit of discount under £120.
I have yet to confirm if the front rings fit as I have not popped the old ones out but they are the same size, as they are for a B9.
The rear RS4 badge is identical, the rear rings are 10mm longer and 2mm taller, I don't think that will notice once fitted. The front grill badge has a different fixing so l have removed the letters from both backing plates and swap them over with new double sided tape.
All good quality as they are OEM and quite inexpensive when you compare what is out there.
Sent from my Pixel 2 XL using Tapatalk
Black Badges
- uplandsway
Re: Black Badges
Thats where I bought all my badges / rings, front ring, rear ring, rear badge and front badge.Toffeebananas wrote: ↑Tue Mar 12, 2019 9:02 pmHave you bought any off this guy? Any pics of them fitted? ThanksRobRS wrote: ↑Tue Mar 12, 2019 6:51 pmYou can get them from these guys - https://www.ebay.co.uk/itm/Audi-A6-RS6- ... Sw4QdaeQJm
Although not cheap, they do look good![]()
All look good and correct as far as my eyes can tell.
Cheers,
Stevie F
2016 C7.5 RS6 Performance
Stevie F
Re: Black Badges
All fitted, very happy with the results.noidea wrote:I have just bought a full set of black badges (front/rear rings and front/rear RS4 badge) from Audi for my B8 RS4. With a bit of discount under £120.
Re: Black Badges
Did you just apply heat to get the old badge off?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Re: Black Badges
Did you mean the rear ones?dannya32 wrote:Did you just apply heat to get the old badge off?
If so yes, a bit of heat and fishing line if you have any.
Don't be tempted to pull them up at an angle as they can dig into the paint and cause a mark.
I then used glue and tar remover to get the rest of the sticky mess off that is left behind.
Re: Black Badges
OK spot on, and did the kit from ebay come with sticky backs already?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Re: Black Badges
I got mine from my local Audi parts dept.dannya32 wrote:OK spot on, and did the kit from ebay come with sticky backs already?
Yes they did come all ready to fit.
Users browsing this forum: Daveperc and 77 guests
