Exhaust tips again
Exhaust tips again
Hi guys dunno if any of you can answer this but want to change to black tips have white car black pack black badges ets with milltek but know there’s issues with pitting ets on some ! Question is can the standard ones be gloss ceramic coated like they do on manifolds etc
Re: Exhaust tips again
I had a set done for the RS4. I had them Zircotec coated. They are a satin black and match really well with the diffuser.
Sent from my Pixel 2 XL using Tapatalk
Loads of posts on this . They can be coated yes from new . I've had mine about 2 months and already Done from winter driving !
2017 C7 RS6 PE Nardo
2014 911 991 C4S PDK White
2013 M6 Cab Blk
2012 911 997 MK2 PDK Silver
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
You had them Zircotec coated and they are pitted!? This is not a liquid coating applied on the surface, a very different process all together.
https://www.zircotec.com/performance-1-coatings/
No I was an idiot ! I'm have a new coating done in May and thought they would last until then and was wrong !noidea wrote: ↑Tue Mar 05, 2019 9:51 pmYou had them Zircotec coated and they are pitted!? This is not a liquid coating applied on the surface, a very different process all together.
2013 M6 Cab Blk
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
Thanks guys so zircotec can even coat the chrome pipe ends ? Any idea of cost ?
They shot blast the tips first, so yes no problem.Afsimba wrote:Thanks guys so zircotec can even coat the chrome pipe ends ? Any idea of cost ?
From memory mine were about £80 the pair.
Had mine shot blasted and the zinc coated gloss black for £60 inc. VAT
Mine are awful, is it bumper off to remove them? Assume you can run without them for a week?
Yes bumper off unfortunately.
chandler99
I've had an interesting response from Audi UK stating "this is a common issue & will not be covered under warranty".
Surely these parts should last longer than 7 months (in my case), surely?
So based on their opinion if something is common then warranty doesn't cover it. What about making these things better in the 1st place.chandler99 wrote:I've had an interesting response from Audi UK stating "this is a common issue & will not be covered under warranty".
My tips were made in China, now that doesn't mean all Chinese products are bad but certainly cost savings have been made!
It really comes down to your dealer and their goodwill, Audi UK seem to be distancing themselves even further away from their own product that they import.
Can drop the exhaust instead but query which is less time consumingab54666 wrote:Mine are awful, is it bumper off to remove them? Assume you can run without them for a week?
