Brake Noise (Squealing)
2.9 V6 24v TFSI - 444 bhp
bing0r
Re: Brake Noise (Squealing)
Post by bing0r » Tue Feb 26, 2019 5:46 pm
Not surprisingly, the squeaking came back the very next day. Took them a week to resolve ( or rather not resolve ) apparently waiting on Audi HQ.
I will most likely speak to them again and see what Audi have to say.
Current: 2018 RS4 B9 Avant
Gone: 2013 RR Evoque Dynamic Lux - Petrol
Gone: 2008 Mazda RX8 40th Anniversary Edition
Markp
Post by Markp » Tue Feb 26, 2019 6:51 pm
There is no fix.It is normal for a RS Audi. It will keep coming back.
We have tried to tell you......
RS4John
Post by RS4John » Tue Feb 26, 2019 7:24 pm
Unless you put Redstuffs in...had mine fitted yesterday. They come with an abrasive coating that aids the bedding in process - no squeal of course, if you are in UK then £171.12 fixes it (both front and back).
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Markp
Post by Markp » Fri Mar 01, 2019 1:59 pm
Hopefully....
Brooner
Post by Brooner » Fri Mar 01, 2019 6:16 pm
or alternatively just stamp on the brakes to clean off the pad deposit build up
always works for me if the brakes start to squeak
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
c99
Post by c99 » Thu Mar 07, 2019 2:38 pm
How to Bed-in/Burnish Brake Pads and Discs: https://www.essexparts.com/support/learning-center--faq
RS5 2.9TFSI
SteveoM
Post by SteveoM » Mon Mar 25, 2019 8:21 pm
So, same squealing for last 3k for me too. Interestingly cleaned the car on Fri, and noticed how the holes in the discs were pretty clogged.
Couple of blasts with jet wash (not on highest power!) cleared them a little.... no squealing for last three days. Could be coincidence, or could be a quick fix!
Anyone else found this?
RS4John
Post by RS4John » Sun Mar 31, 2019 11:47 am
Was tidying up in the garage yesterday and junked the RS4's OEM disc pads - because the garage is most likely damp from time to time as cars are driven straight in when it's raining it was curious to see that the surface of the pads were flecked with rust...there is ferrous material in those pads. Metal on metal will squeak unless lubricated however not a viable option for friction materials.
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Markp
Post by Markp » Sun Mar 31, 2019 12:50 pm
The opposite actually John - iron is used for high performance pads as it increases ability to handle heat and gives pad better friction under high loads, so is used in performance pads as in the RS. The downside is that it performs less well at low speeds. Copper is the other commonly used alternative and has the opposite properties - good at low speeds (and likely to be quieter) but can't cope so well with heavy brake loads. Put simply this is one of a number of reasons high performance pads squeal at low speed, and eat discs.
RS4John
Post by RS4John » Sun Mar 31, 2019 2:54 pm
Thanks Markp!
I'm pretty certain there isn't any iron in the EBC Redstuff pads - the boxes are labelled 'Ceramic'.
DP32277C - Front
DP32254C - Rear
Bedded in, better initial bite over the OEM pads and then noticeably more effective and of course little dust with minimal disc wear, not a lot not to like.
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Markp
Post by Markp » Mon Apr 01, 2019 8:56 pm
"Ceramic" are typically a mix of ceramic and copper (normally). No iron. But often harder on discs than non ceramic / iron based. But varies a lot from pad to pad. Basic overview here: https://www.searsauto.com/car-care-101/ ... brake-pads
Ceramics more expensive so less money for Audi ;)
RS4John
Post by RS4John » Tue Apr 02, 2019 8:33 am
From the EBC Redstuff product page https://ebcbrakes.com/product/redstuff-brake-pads/ - and the Technical information tab they wrote:
"This material is a aramid fibre based brake compound enhanced with ceramic particles. If you have previously tried EBC redstuff (pre-ceramic compound) this material is light years ahead. It lasts longer, it brakes better and is quieter. (John - In looking into Aramid Fibre as a disc pad compound I encountered a research paper that cited a tenfold decrease in disc wear).
Being a hard wearing pad, bed-in times can be as long as 1000 miles and drivers must be patient until the pad takes up the shape of their disc (brake rotor). This is a truly impressive fast road pad for repeated heavy braking.
It emits far less dust than semi-metallic pads and has been proven to stop a passenger car/sedan/sport compact/hot hatch 13 metres quicker than OEM pads from 100mph/160kph. Features EBC Brake-In surface coating which conditions rotor surface and accelerates pad bed-in. Nominal friction coefficient 0.5 with approx. 50% dust reduction.
Most EBC Red Ceramic pads are approved to ECE R90 brake safety regulation."
I can vouch for the 1000 mile bedding in period, as with the prior RSQ3, the disc rotors are being polished mirror-like rather than having the surface ground away. For myself I wanted to avoid the pain of needing new front discs at 30,000 miles as happened with the previous vehicle, and the 4's silver Edge wheels are a huge pain to keep clean so the very light brake dust/wash off with a sponge characteristics are welcomed.
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
s4tokyo
Post by s4tokyo » Sat Apr 13, 2019 1:45 pm
Have been reluctant to pitch in here because of inevitable flack outpour but, as it's an Audi Dealership recommendation and it works as a very S/T solution, I've opted go for it and share.
Re brake squealing, a band aid fix for driver not 'using' the brakes as firm and often as is ideal / not covering a lot of miles, 'a' short term countermeasure not recommended but used by Dealers here, is "Tapping Fluid" (spray).
4 dot squirts on the disks and you're ready to go - for a few days;-) ZERO squeal. If you're not driving hard, not in the market for changing pads, ....or for stomping on the brakes a few times at speed (as has wisely been recommended), then I can vouch for this alternative Plan 'other' S/T countermeasure.
The obvious reaction is that 'isn't that like putting oil on brake pads ...and inviting accident?', but I have not found any notable concern. Just 4 spray dots - a SMALL amount - around each disk and the irritating squeal disappears, for a while.
Not much value as a corrective countermeasure to most perhaps, but FWIW.
Current :Sonoma Green. Ext Black Pack, Carbon 'Ext/Eng Cover/Int trim', Sports Exhaust, RS Sports Int., Pana Sunroof, Matrix Lights, Park & Drive Assist pkg., Speed limiter removed, Titanium-Anthracite 20".
Previous : B8.5 RS4 Daytona Gray
Previous : B8 S4 Ibis White
johnnydog
Post by johnnydog » Fri Apr 19, 2019 12:20 pm
I know this is the B9 forum, but I had a lot of issues with the brakes on my B7 with judder which Audi rectified eventually under warranty with ceramics :kissmyrings: All the problems instantly went away and they were still performing superbly when I sold it some 5 years later.
This influenced my decision to get a B8 with ceramics, and 4 years on, no brake dust, no squeal, superb performance, plus they look tremendous with the massive disc and prominent grey caliper with the 'Audi Ceramic' logo!
Reading all this makes me glad I got a car with the ceramics option......!!!:thumbs:
Not that this helps you guys out there....sorry :|
PieterZ
Post by PieterZ » Fri Apr 19, 2019 12:55 pm
Indeed, I have nothing to complain about neither.
All black B9 RS4
Users browsing this forum: No registered users and 8 guests
