Help
4.2 V8 32v Naturally Aspirated - 444 bhp
Wiggers
Help
Post by Wiggers » Thu Mar 07, 2019 11:54 am
Can anyone help me on this? After 20 miles or so i get tpms, electronic handbrake, sports differential and stability warnings all at once. Limp modeis activated, turning off and on gives power back but lights remain until a mile or so down the road. Im thinking from the codes there is a module power issue but i dont know where to start looking. Any help will be much appreciated.
Thursday,07,March,2019,10:14:43:32264
VCDS Version: Release 11.11.3
Address 01: Engine Labels: 079-907-560-CFS.clb
Control Module Part Number: 8T1 907 560 HW: 8T1 907 560
Component and/or Version: 4.2l V8HDZ / H04 0007
Software Coding: 0114000C240F0168
Work Shop Code: WSC 32264 000 1048576
ASAM Dataset: EV_ECM42FSI0118T1907560 001018 (AU48)
VCID: F8F5763943C8EA9
3 Faults Found:
4698 - Function Restriction due to Received Malfunction Value
U1113 00 [044] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Mileage: 133665 km
Date: 2019.03.06
Time: 10:07:22
4699 - Function Restriction due to Received Malfunction Value
U1113 00 [036] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 133699 km
Date: 2019.03.06
Time: 21:00:02
14351 - Throttle Position Sensor Bank 2
P2131 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 133695 km
Date: 2019.03.06
Time: 20:55:04
Readiness: 0000 0001
Thursday,07,March,2019,10:16:15:32264
Address 03: ABS Brakes Labels: 8K0-907-379.clb
Control Module Part Number: 8T0 907 379 HW: 8T0 907 379
Component and/or Version: ESP8 quattro H04 0200
Software Coding: 2C0D2A
Work Shop Code: WSC 06325 000 00000
VCID: FF079D256EE6DD1
3 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 4
Reset counter: 125
Mileage: 133665 km
Time Indication: 0
Date: 2019.03.06
Time: 10:07:22
Freeze Frame:
Hex Value: 0x4100
Hex Value: 0x4006
Hex Value: 0x1226
Hex Value: 0x46B9
Hex Value: 0x00FF
01324 - Control Module for All Wheel Drive (J492)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 125
Mileage: 133665 km
Time Indication: 0
Date: 2019.03.06
Time: 10:07:22
Freeze Frame:
Hex Value: 0x4100
Hex Value: 0x6206
Hex Value: 0x1228
Hex Value: 0x50B8
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 125
Mileage: 133665 km
Time Indication: 0
Date: 2019.03.06
Time: 10:07:23
Freeze Frame:
Hex Value: 0x4300
Hex Value: 0x6206
Hex Value: 0x1233
Hex Value: 0x02B7
Hex Value: 0x00FF
Wiggers
Re: Help
Post by Wiggers » Thu Mar 07, 2019 11:55 am
*2011 RS5
morski
Re: Help
Post by morski » Sun Mar 10, 2019 9:22 pm
Ia it still on the original battery? if so worth changing it and coding the new one to the car and then see what faults you have
RS6 Performance Ascari blue, Carbon Ceramics, Akrapovic, H&R Anti Roll bars
Return to “RS5 (8T) 2010–2015”
Users browsing this forum: No registered users and 52 guests
