“Inspection service” at 3 yrs
tonybrown5
Re: “Inspection service” at 3 yrs
Post by tonybrown5 » Fri Mar 01, 2019 3:39 pm
Thanks Mike. It's in for a couple of warranty items next week so I'll get them to do it then.
Nick_T
Post by Nick_T » Fri Mar 01, 2019 3:47 pm
I've just been quoted £350 for a minor service (inspection + oil change I believe) plus £85 for the brake fluid change from Audi garage, they say they can do it all in 1.5 hours while I wait with 2 technicians working at once on the car (assuming I don't want the car cleaned which takes an extra 30 mins). Does this seem reasonable?
Post by MikeFish » Fri Mar 01, 2019 3:53 pm
Are they trying to tell you it needs an inspection service as well or did you decide to have the service done at the same time?
Nick_T
Post by Nick_T » Fri Mar 01, 2019 4:01 pm
They are saying they will do a "free" heath check and look up and do what is required, if it only needs brake fluid that's all they'll do. I suspect it is just that, brake fluid only and MOT with the minor service / oil change being due in 4 months / 4.5k miles based on flexible service schedule (roughly 13 months from previous oil change).
Afsimba
Post by Afsimba » Fri Mar 01, 2019 8:26 pm
Mines due inspection in 30 days and oil in 120 or so seems daft not to have both at once but only covered 16k in 3 yrs and had an extra service past schedule already
Anth
Post by Anth » Sat Mar 02, 2019 9:54 am
Nick_T wrote:
Thu Feb 28, 2019 10:35 pm
I don't plan to sell any time soon. It is still within warranty (bought from Audi so had extended warranty until May) so maybe going to Audi this time will be beneficial so I can try and pick up any issues under warranty.
I was thinking it might be easier just to get it all done in one hit, seems a little excessive / expensive to pull the oil change service in by 4 months especially if this happens on a regular basis but maybe I need to stop thinking about saving a few quid!
Trying to get my head around the servicing intervals of the car, can't seem to find reference to what to expect from a quick search around. Bought my wife's Q5 at the same time and that isn't saying anything is due yet despite covering more miles, I presume her service intervals on a 3.0 TDI 2016 Q5 differ from the RS6, to be expected with a performance car.
These inspections are just a boost by Audi on the RS one there not inspections there normally teamed up with oil /fluid/filters and so you take the car in to them . Let's face it the oil is £130/£150 to do at a specialist as long as they run it to temp and use the 2 drain points save your self a few quid maybe unless Audi will sort you a deal if you have 2 cars with them if be looking for one Nick .
Ps. If you have a Pan roof that's on the 40k service too / re oil and clean . So sparks - Diff oil - gear box oil - pan roof depending on what you had done first .
2017 C7 RS6 PE Nardo
2014 911 991 C4S PDK White
2013 M6 Cab Blk
2012 911 997 MK2 PDK Silver
2007 RS4 Cab Grey
Wattsm666
Post by Wattsm666 » Sat Mar 02, 2019 12:21 pm
It is all a bit confusing, my car was booked in for a service yesterday, which needed an oil service at 23,000 miles. Inspection was not for another 8,000 miles.
Now it has been serviced the inspection is showing as due at a much higher mileage interval than it was pre oil service yesterday.
Tadass910
Post by Tadass910 » Wed Mar 20, 2019 5:48 pm
Actually gearbox oil no need to change for Rs6, Audi already said that, I asked 2 dealers already
Nick_T
Post by Nick_T » Wed Mar 20, 2019 6:08 pm
I'm completely confused by my service interval now. I went to Audi as it showed inspection due. Thanks to you guys it was pointed out this was 3 year brake fluid change and nothing more, Audi confirmed as much and stated nothing else was due after a full check and proceeded to change brake fluid and nothing more. On checking the vehicle service section on the car the intervals now showing don't make sense to me.
Pre brake fluid change:
Next oil change in 4200 mi / 126 days
Next inspection in 3500 mi / 16 days
Post brake fluid change / inspection:
Next oil change in 9000 mi / 365 days
Next inspection in 3400 mi / 730 days
I queried before leaving the garage and was reassured that everything is as it should be and is perfectly normal. Thought I'd check with you guys.
Not sure why oil change is now pushed out despite no oil change occurring. Last oil change was 10.5 months ago and approx. 7.5k miles.
Inspection isn't now due for 2 years but mileage to next inspection hasn't changed? Is there something due at approx 20k miles?
Car is 3 years old exactly and has 15.5k on the clock. RS6 with panaramic roof, carbon ceramic brakes, not PE.
Thanks for any insight anyone can give! Is there an online form showing service intervals for RS6? Or is it dependant on driving style etc.?
Cheers!
Sent from my Pixel 2 XL using Tapatalk
Post by MikeFish » Wed Mar 20, 2019 7:23 pm
Looks like they reset the oil change to me. 9000 miles or 365 days is exactly the oil change interval when on annual servicing.
Nick_T
Post by Nick_T » Wed Mar 20, 2019 7:37 pm
That's what I specifically asked the service manager about as I checked before leaving the garage. They came out and said it was all checked over on their computer and set to what it should be. I'm not convinced it is correct.
It might be on flexible servicing at the moment, I'm uncertain. What should oil change be for a RS6 on flexible servicing, is it dynamic based on driving style, is oil quality checked by some kind of probe?
Going by original service interval figures displayed in the car before taking it in for the inspection it seemed to have estimated oil change was due in a total of 11k miles / 14 months since last change, this seems like odd numbers to me. Unless they reset intervals when doing work on the car previously without me noticing. Any thoughts?
Tadass910
Post by Tadass910 » Wed Mar 20, 2019 7:53 pm
Normally I change oil at Audi dealer every 15000km
Post by MikeFish » Wed Mar 20, 2019 8:48 pm
The fixed servicing is 9000 miles / 12 months, whichever comes first.
If it's on the variable service then I think it's up to 18,000 miles / 2 years but this normally goes down based on how the car is driven. I recall someone telling me (this was about a B7 RS$, but the logic is probably still the same) the car can judge the state of the oil and therefore the service interval by who long it takes the oil to heat up (and cool down?). This is the best explanation I have seen to make any logic out of how the car knows when the flexible service is due.
I'd put money on them resetting the oil service given those numbers. Not sure why it is is still expecting an inspection in 3400 miles. Something else must be due then, perhaps spark plugs?
Post by MikeFish » Wed Mar 20, 2019 8:49 pm
This is the fixed servicing; 15000 km is 9000 miles.
Users browsing this forum: No registered users and 144 guests
