Extended warranty question
guyneutron
Post by guyneutron » Tue Feb 26, 2019 11:40 am
Hi all,
Had a service done at an Audi specialist a couple of months back(11000 miles)
Around August my warranty will expire and I am looking to extend it. Will the fact that I did not go to a dealer effect the possibility of extending my warranty?
jwlanky
Re: Extended warranty question
Post by jwlanky » Tue Feb 26, 2019 2:00 pm
Plug your details in a see if it gives you a quote...https://www.insurewithaudi.co.uk/extended-warranty
Golfather
Post by Golfather » Tue Feb 26, 2019 3:39 pm
As long as they used genuine parts its fine. However after the warranty starts, then u need to use a stealer
DaytonaMatt
Post by DaytonaMatt » Wed Feb 27, 2019 6:38 pm
Are you sure? I read the terms yesterday and seemed pretty clear it's parts need to be audi approved, but no mention of it having to be performed by Audi?
- Servicing must be carried out in accordance with vehicle manufacturer recommendations. Genuine Audi components, oils and other fluids or components, oils and other fluids of equivalent specification and matching quality must be used. Failure to comply with this condition will result in a warranty claim being rejected.
- Failure to keep your vehicle serviced in accordance with the manufacturer’s service schedule will void the warranty. You must keep all servicing receipts and invoices. We will be entitled to check that your vehicle has been serviced regularly and may ask to see these in the unlikely event that the condition of your vehicle does not appear to correspond with your vehicle service schedule
- Modification to the vehicle – If you would like your vehicle to be modified in any way, you should obtain our prior approval and the work should be carried out by an Audi Approved Centre. In the event that a modification, which was not approved by us, contributes to a fault, we reserve the right to reject any claim you may wish to make in relation to that fault.
Anth
Post by Anth » Thu Feb 28, 2019 9:12 pm
I can't remaber who Audi use now to extend I had it n my last C7 none FL and sure it was Lawshield UK If so as DMatt said you can use any approved garage for works no issue .
2017 C7 RS6 PE Nardo
2014 911 991 C4S PDK White
2013 M6 Cab Blk
2012 911 997 MK2 PDK Silver
2007 RS4 Cab Grey
Users browsing this forum: No registered users and 398 guests
