Does DRC leak on the floor?
4.2 V8 32v FSI - 444 bhp
robster
Post by robster » Thu Feb 07, 2019 10:11 pm
Picking up my RS4 next week, anyone got a guide on checking the DRC? Will leaks be obvious or do I need to get underneath the car to check the shocks and the steel pipes?
dhali
Re: Does DRC leak on the floor?
Post by dhali » Thu Feb 07, 2019 11:17 pm
In my case when it went was all over the rear diff and exhaust and floor
HB_NORM
Post by HB_NORM » Fri Feb 08, 2019 12:05 am
Just had mine go on the O/S front shock. No oil on the floor, just under gator of shock and running 5 PSI.
robster
Post by robster » Fri Feb 08, 2019 7:41 am
Cheers fellas, if system sealed what should the pressure read if I ask them to test it? Car from main dealer so they should have the equipment
innercry666
Post by innercry666 » Fri Feb 08, 2019 9:54 am
20 PSI.
RS6 PE - Current
RS4 (B8.5) 2015 - Sold
A4 3.0 TDI Quattro BE Avant - Gone
Focus ST170 - Garaged
HB_NORM
Post by HB_NORM » Fri Feb 08, 2019 5:46 pm
23 PSI I was told. Guess around that mark is reasonable.
MK2Golf24v
Post by MK2Golf24v » Fri Feb 08, 2019 6:14 pm
You are all wrong.
It’s Bar, not PSI 18-22 is the range.
robster
Post by robster » Sat Feb 09, 2019 7:45 am
Cheers guys
20 bar is quite a lot pressure, hope nothing fails catastrophic
