Oil usage
Re: Oil usage
A litre will almost get you to the top.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Re: Oil usage
I think from min to max is 1.5l
Re: Oil usage
Cheers,
Do you get yours from the dealers?
Re: Oil usage
Just check the level again fresh, on a flat surface;
Open and close bonnet,
Turn on engine but do not start
Go into oil level and it will say it will be displayed in 2 minutes.
No need to go to the dealer, but are you on annual or longlife servicing as the oil is different I believe.
Longlife is spec VW 504 00, fixed VW 502 00, normally 5w 30.
Re: Oil usage
Pretty sure the dealer puts the same oil (504) in now regardless of service regime.ab54666 wrote: ↑Thu Jan 24, 2019 8:50 pmJust check the level again fresh, on a flat surface;
