Alternator whine with aftermarket headunit
jordanbutters
- 1st Gear
I've recently installed a Kenwood DAB CarPlay HU in my RS4. I used a Connects2 loom and it's all playing nicely with the BOSE system, except I get audible alternator whine no matter what the audio source is. I've checked all the connections and nothing is touching where it shouldn't be.
Does anyone have any experience with curing this without resorting to ground loop isolators? Don't mind running a new earth or two if it means not losing sound quality (I understand isolators kill a lot of the bass quality).
jordanbutters
- 1st Gear
Re: Alternator whine with aftermarket headunit
No one else experienced this?
I had the same alternator whine issue after installing an aftermarket kenwood head unit. I was able to sort it by installing a couple of ground loop isolators. So far no issues and no engine noise through the speakers
I had it with my aftermarket amps with standard head unit and then with aftermarket head unit too. I tried everything including running an earth cable from amp to head unit to make sure there was no ground loop. In the end the only thing that fixed it was a ground loop isolator. I used it with some pretty decent kit and couldn't hear any loss in quality. In fact with the humming gone it was much improved.
Can I fit one of these even if I’m using a Bose harness? I’m assuming it just goes invetween one set of speaker phone cables to work?
They normally need to go between the head unit and amplifier. What do you mean by speaker phone cables?
My one was had RCA plugs / sockets to pug into the amplifier input.
I meant phono cables, rca cables. My harness goes in between the Audi harness and my head unit with rca cables for speaker cables. So I would assume that they go to the amplifier but there are two sets, one for the front and one for the back. So do I just need to put it in one set?
Are you getting whine from front and back speakers? If so then you need one on both sets.
I’m not really sure to be honest but now I know I need one for both front or back. I’ll look into it more and do something about it. Thanks Mike
jordanbutters
- 1st Gear
Did you try any alternative methods such as running new grounds?
Users browsing this forum: No registered users and 239 guests
