Audi adaptive light: system fault
FinlandRS6C7
- 1st Gear
Hi.
I try to take off this useless automatic fogmode. And i change only rainlight bit off. I take old code photo. And then car give me this and high beam automatic dosent work. 2 faultcodes right and left matrix led not calibrated. I took back this rainlight bit and code is exactly same that before i no nothing. But still give same faultcode ecu55headlightrage. Can somebody help me. Car is 2016 rs6 with matrix led.
Re: Audi adaptive light: system fault
I find faults like this go away after a good charge of the battery.
FinlandRS6C7
- 1st Gear
- Surrey Sam
Sounds like you need to get it re-calibrated. Changing the coding may have wiped the original calibration.
FinlandRS6C7
- 1st Gear
Yes. But how this done? Because code os identical what is before i try this change?Surrey Sam wrote: ↑Thu Jan 10, 2019 12:36 pmSounds like you need to get it re-calibrated. Changing the coding may have wiped the original calibration.
- Surrey Sam
Audi dealership needs to calibrate the headlight system. Coding is not calibrating, I think your calibration was deleted when you played around with coding.
FinlandRS6C7
- 1st Gear
Yes. I think so too. How this calibration have to do?Surrey Sam wrote: ↑Tue Jan 15, 2019 6:37 pmAudi dealership needs to calibrate the headlight system. Coding is not calibrating, I think your calibration was deleted when you played around with coding.
Can somebody send me full autoscan in fl audi rs6 mine is 2016 with matrix led
FinlandRS6C7
- 1st Gear
Now lights are recalibrate and works fine.
zappy-chops
Excellent. Love a happy ending.
Currently running:
18 plate Lamborghini Huracan Performante (5.2l of V10 naturally aspirated craziness)
67 plate RS6 Performance (fully loaded)
66 plate Range Rover Autobiography (for wafting around)
16 plate Mini Cooper S convertible (lots of fun but rather skittish when thrashed)
Favourite car ever owned:
1971 Citroen DS21 - The Goddess (pure art on wheels)
FinlandRS6C7
- 1st Gear
Yes me to
Users browsing this forum: morski and 83 guests
