10k km and I need a new seat, I advise to read this.
2.9 V6 24v TFSI - 444 bhp
Markp
Re: 10k km and I need a new seat, I advise to read this.
Post by Markp » Thu Sep 27, 2018 7:17 pm
Strange bolt and looks like seat out. Sadly.
PieterZ
Post by PieterZ » Thu Sep 27, 2018 7:52 pm
I haven't checked thouroughly, but at first sight it is a bigger torx size.
There is some space but not much.
Maybe you can get a bit in and turn it with a spanner that fits the drive side.
A wrench won't fit.
Seat out will be easier, or at least undo the inside and loosen the outside bolts near the door and you may be able to tilt it a bit.
Changing upholstery is defenitely seat out.
Nothing dramatic, I had my seat upholstery changed on my previous car due to burnt heating.
A bit decent mechanic can do it, but changing the upholstery is fiddely.
I will leave it to the pro's as it's a warranty issue.
All black B9 RS4
0xSam
Post by 0xSam » Fri Oct 19, 2018 12:38 pm
I was at my audi dealer today and already got an email that its covered by warranty and I'll get a complete new seat pad within 4-5 weeks.
Apparently, audi needs to put some sort of protection arround the belt-holder as well (Because changing the angle might not be possible from a security point of view).
-Audi RS4 B9 | HRE P107 20" - Gloss Black
-Nissan GT-R MY2015
PieterZ
Post by PieterZ » Fri Oct 19, 2018 5:52 pm
Correct. Mine has arrived at the dealer a few days ago, I'm booked for nov. 14.
The angle can be changed. Some seats are ok some are too low.
I presume they just hold it by hand and then screw it on.
All are fastened in different angles. Defenitly not a jig used in assembly.
Driver's seat is rubbing a lot, passenger side is ok.
The last stockcar at the dealer was rubbing on the driver's side but not as much as mine.
That passenger's side was also ok on that car.
All black B9 RS4
AndyL
Post by AndyL » Fri Oct 19, 2018 7:05 pm
Spoke to my local audi dealer today and they have the bottom seat cover on order for me (covered by warantee) they have also confirmed they will adjust the angle of both front seat seatbelts.
PieterZ
Post by PieterZ » Fri Nov 16, 2018 6:22 pm
My seat issue was solved on wednesday. A new bottom seat upholstery was installed.
It was covered by the warranty.
I posted some pics in my readers’ ride thread.
All black B9 RS4
AndyL
Post by AndyL » Sat Nov 17, 2018 12:28 am
Mine was also repaced today, they also fitted some felt to the seat belt holster to reduce friction inorder to prevent it from happening to the new seat. Supprisingly I had to argue with them to also apply the felt to the passanger side seat belt aswell. I will post some pictures later this weekend.
PieterZ
Post by PieterZ » Sat Nov 17, 2018 1:09 pm
That felt isn’t really needed. I only have it on the drivers side.
Now the buckle isn’t contacting any more.
All black B9 RS4
AndyL
Post by AndyL » Sat Nov 17, 2018 11:38 pm
Did they adjust your buckel? I was told that they couldnt/wouldnt adjust the angle and that Audi had told them to install the felt only.
PieterZ
Post by PieterZ » Sun Nov 18, 2018 2:03 am
Yes they did. There was not a lot of adjustment due to a positioning pin.
But they managed to adjust it like on the passenger's side.
The buckle now doesn't make contact any more.
Take a look at the before and after pics in my reader's rides thread. You can see the difference.
Only the felt is no cure the issue will return if they don't solve the cause.
All black B9 RS4
0xSam
Post by 0xSam » Thu Dec 13, 2018 1:06 pm
Had my replacement seat delayed until january.
-Nissan GT-R MY2015
PieterZ
Post by PieterZ » Fri Dec 14, 2018 1:19 pm
Well that sucks. I suppose the factory has to work overtime to get all these done.
All black B9 RS4
0xSam
Post by 0xSam » Sun Jan 13, 2019 10:23 am
Got the new upholstery done this friday. The buckle now has a steeper angle as well, I just think that the protection arround the buckle is only half-assed. It doesnt even cover the whole buckle - just the upmost part - and the material is very thin. I'm probably gonna buy a seat belt protector, cut it in half and fit it over the buckle.
-Nissan GT-R MY2015
PieterZ
Post by PieterZ » Sun Jan 13, 2019 8:09 pm
The velcro like protection isn’t really needed.
If all is well the buckle just passes the seatbase.
I have no more issues.
All black B9 RS4
Crawfc
Post by Crawfc » Mon Jan 14, 2019 11:17 pm
A slightly linked point, but is it only me where the passenger seat buckle (when the seat is not used) clanks against the hard shell of the seat. Seat has to be really far forward or back to avoid
