Snapped rear spring
5.0 V10 50v biturbo - 571 bhp
c3nturi0n
Snapped rear spring
Post by c3nturi0n » Sun Jan 13, 2019 2:02 am
hiya,
and hope you all enjoyed time off during festive season... offside rear springs is snapped on my car and i'm contemplating on the idea to replace potentially all four with H&R equivalent with standard OEM height (as opposed to OEM ones). Any thoughts or suggestions?
or should I keep it simple and stick to OEM springs and replace both rears (incl. the bump stops as those are also showing sign of wear).
Pls advise (and thx).
2008 RS6 Avant (Monza Silver)
- H&R ARBs
Toady1
Re: Snapped rear spring
Post by Toady1 » Tue Jan 15, 2019 10:41 pm
It depends if you want it lower or not really, that's all.
c3nturi0n
Post by c3nturi0n » Wed Jan 16, 2019 4:30 pm
H&R's provide 30mm drop which will add to stiffness on an already stiff suspension :)... so I guess my follow up to this would be - if I was to go ahead with H&R springs, can I retain existing shocks? and with replacement in mind, anything I should consider re DRC?
- H&R ARBs
IanH755
Post by IanH755 » Fri Jan 18, 2019 7:09 am
Retaining Shocks - Yeap, the H&R's fit over the existing DRC shocks and, as you siad, will further increase the stiffness of the car (possible negative) whilst the lowering looks better.
Anything Else - There's no aftermarket Camber Adjustment kit for the RS6 and the OEM doesn't have enough adjustment to fully "level" the tyre so you WILL wear the inner edges of your tyres faster than a n OEM height car, it's a very common complaint on here about lowering.
FUBAR
Post by FUBAR » Fri Jan 18, 2019 2:46 pm
You can correct camber to some degree with this kit:
https://ukwhitelineperformance.com/coll ... ushing-kit
And caster with this kit:
https://www.summitracing.com/int/parts/ ... i/model/s6
08 RS6 by Reperformance, MRC MAP. 977 PS - 1320 Nm.
IanH755
Post by IanH755 » Sat Jan 19, 2019 9:32 am
Thats great, I think that needs to be advertised a bit wider as I know a few people were put off lowering before.
c3nturi0n
Post by c3nturi0n » Mon Jan 21, 2019 6:35 pm
Cheers guys that's super useful.
as suggested, I think we should do the sticky with this thread to assist other users if/when lowering their cars.
- H&R ARBs
c3nturi0n
Post by c3nturi0n » Tue Feb 26, 2019 12:26 pm
FYI - it turned out to be false positive.
Mis-diagnosed by local Audi specialist due to lacquer peeling off on the rear spring :)!
- H&R ARBs
RS6-T28RPH
Post by RS6-T28RPH » Sun Mar 17, 2019 9:57 pm
Just to chuck my 2 pennies worth in, I did have a snapped rear spring and have just gone for the KW height adjustable spring kit, paid about £725 for it but had to be shipped from germany so expect a 4-5 day lead time if ordering direct from KW UK.
With regards to height settings, as a rough guide to get a 1 finger gap between top of tyre and arch you need to max out the rear spring adjuster so the purple adjustment ring is flush with the bottom of the threaded part. For the front about 20mm between the bottom purple adjuster and the bottom of the threaded part.
Seems I have had a broken spring for a while so hard to get an accurate comparison but the car feels a lot tighter now :-)
Esben Business IT Solutions - http://www.esben.co.uk
Esben Remapping - http://remap.esben.co.uk
2015 BMW X6 M50d (wife-transport, not allowed to touch :cry: )
2008 RS6 Avant Phantom Black - MRC Stage2 (ecu, tcu & 2nd cat bypass) 730 PS/1017 nm
2006 BMW 535d Pre-LCI - Stage 1 (340bhp)
2003 VW Polo 1.4Tdi (3pot shitbox) tuning project, was 73bhp, now 120bhp, aiming for 160bhp before it goes bang! (put in the bin)
RS6-T28RPH
Post by RS6-T28RPH » Fri Apr 26, 2019 10:35 am
ignoring the state of the car, photo to show ride height of the KW setup. rears are wound up as much as possible, fronts have 20mm between the top and bottom of the adjustment collars
