Squeaky Suspension
rs4jas
Squeaky Suspension
Post by rs4jas » Sat Jan 12, 2019 5:26 pm
Hi I have a RS4 B7. I’ve recently changed out the DRC system for a bilstein B14 coilover kit. New top mounts. All upper front arms and drivers front lower rear arm. Also polybushed anti roll bar bushes. There’s a REALLY annoying squeak coming from the drivers front and it’s doing my head in. It sounds like a squirrel is in my wing. It happens constantly when driving no matter what road surface.
Any ideas? Don’t want I change anything just to guess.
alex760
Re: Squeaky Suspension
Post by alex760 » Sat Jan 12, 2019 11:16 pm
I've had squeaks from polybushes in the past, especially powerflex ones. Could be those?
Seattle-squash
Squeaky Suspension
Post by Seattle-squash » Sat Jan 12, 2019 11:46 pm
rs4jas wrote:Hi I have a RS4 B7. I’ve recently changed out the DRC system for a bilstein B14 coilover kit. New top mounts. All upper front arms and drivers front lower rear arm. Also polybushed anti roll bar bushes. There’s a REALLY annoying squeak coming from the drivers front and it’s doing my head in. It sounds like a squirrel is in my wing. It happens constantly when driving no matter what road surface.
Unfortunately the coil-over systems are often a bit noisy, especially at low speed over speed bumps etc... and got some light creaking myself with my B16. I spent lots of time trying to silence it 100% but eventually gave up with mostly all new parts. I think often it’s the coil springs binding against themselves which is tough to fix.
rs4jas
Post by rs4jas » Sun Jan 13, 2019 8:50 am
Ohhh ok. Just wondered if something was wrong as it didn’t squeak at 1st but after a couple of weeks it started. What if I lifted the front up? Have you tried that? Does that quieten it down?
Covkiller
Post by Covkiller » Sun Jan 13, 2019 10:07 am
You can lubricate your springs and top mounts, you could use sillycunt lubricant:
https://www.amazon.co.uk/WD40-Performan ... B00KPUBRJ8
rs4jas
Post by rs4jas » Sun Jan 13, 2019 10:19 am
Awesome I’ll give anything a try.
jamiej
Post by jamiej » Sun Jan 13, 2019 10:40 am
Don't the B16s have a different piston protector, like a corrugated sleeve, whereas the B14s have a straight sleeve, could this be causing the sqeak?
Sent from my ONEPLUS A6013 using Tapatalk
Current
'07 - Audi RS4 Avant Daytona Grey
'16 - BMW M135i F20 (LCI)
'53 - Land Rover Range Rover Vogue 4.4 V8
Gone
'02 Audi 8L A3 1.9 TDI (PD)
'03 Subaru Impreza WRX STI
'96 VW Golf VR6
'91 Toyota MR2 NA
'90 Peugeot 205 GTI 1.9
'90 VW Mk2 Golf GTI 8V
MrRSB7
Post by MrRSB7 » Wed Jan 16, 2019 11:17 pm
C’mon now, no need for squirrel talk 🐿
2006 2-tone merlin purple , decat delete, res delete, x-pipe and rear back box delete......rs5 alloys.. silver brake callipers
coombsie66
Post by coombsie66 » Fri Jan 18, 2019 9:57 am
I have exactly the same from my Bilsteins, thought it was the arm bushes being under torsion from tightening the bolts with the arms in droop - so re-did those with the arms in the correct position - no change.
I think it is damper shaft dust cover/sleeve rubbing on the inside of the coils as the squeaking is far less in the wet and seemed to go away for a while after lubricating the sleeve.
Pretty pathetic fault from a manufacturer like Bilstein to be honest.
Wondering if some zip ties around the sock to pull it in a touch might help?
marc1
Post by marc1 » Fri Jan 18, 2019 2:51 pm
There is a known issue with B14’s squeaking from memory. If you google or search this forum with B14 included in the key words. Doesn’t apply to B16’s from what I remember.
Users browsing this forum: QuRace and 174 guests
