What you guys using for logging??
I use HEX+CAN VCDS but its sample rate is poor even measuring just one block
ECU Logging
ECU Logging
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Re: ECU Logging
I guess not many folks on here want to see what their engine is doing. I suppose not much of a consideration unless mapped.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Re: ECU Logging
Depends what you want to see and whether you just want to see it as you drive or actually make a log.
I've used Bluetooth obd dongles with an app on a tablet before. Had good responses but limited as to what you could actually measure. And I don't think it actually logged the info.
Re: ECU Logging
Yes I want a log saved.
VCDS used to be very good but seems slow with the newer ecus.
Boost, timing, knock, afr, Revs. If I log them all at once the sample rate is very very poor. Might try OBDeleven and see if it’s any better
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
- Surrey Sam
Re: ECU Logging
Logging more than 1 group will reduce the sample rate, have you tried Turbo mode?
Re: ECU Logging
Yes I use turbo mode. I have changed some settings I found in VCDS forum. Will try that and see.
Using Ecutek on the GTR I could log 7 or 8 outputs and still return 2 or 3 samples per 100 revs
With VCDS I am lucky if I see 1 per 500rpm. Very poor. I don’t think VCDS is keeping up with ecu evolution
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Re: ECU Logging
OBD11 kinda can keep up with multi (7-10) parameters...but if you try to graph log (and save them) that indeed goes bad soon.
Your best luck might be live logging non graph and try to record it with other device or screen recording if there is an app able to do that.
If not mistaken, our ECU can only display 8 parameters....at least that is what my FIS mmi gauge module max can (be working with creator to run multi cfg files for more parameters).
Users browsing this forum: No registered users and 44 guests
