Modify Genuine RS6 Sports Exhaust
- Mr Footlong
Re: Modify Genuine RS6 Sports Exhaust
Dave, based on the price that I have seen those backboxes going for, you are going to save an absolute packet even if you just get them new and use my bits?
The deal isn't signed in blood, you can bow out if you want, not the end of the world whatsoever but was nice and easy for me is all.
Current:
Gone:
Gone:
Hi Footers,
Deal is done from my perspective - just seeing if anyone has some back boxes "used" versus new. Already found some good prices new, but worth asking here!
I could do as MIke suggested and get a fabricator to make up a piece, but to be honest that's too much faff. And if I take the whole "Sports Exhaust" off it may be of interest to someone so I recover more of my costs!!
I'm not in a hurry to put the new system on - will probably get done at the same time as the tune in the spring!
Mike
Dave
Mike
- erm, thanks for the non-offer!! If you happen to change your mind then let me know!I do happen to have both rear silencers sitting on a shelf but you can't have them.
Dave
- Mr Footlong
Kewl and lol@Mike
Current:
Gone:
Gone:
Just for you Dave, here they are:
Interesting!! They don't look the same as these!
Yours don't appear to have the triangular cross-section.
- Mr Footlong
Dave, that looks dead on the the left box in the Milltek pic you attached to me.
Current:
Gone:
Gone:
This mine looks exactly the same
- Mr Footlong
Christ, when you see it laid out like that, add in my sports cats and I can really understand just how this car is sooooo loud with the valves open.
Current:
Gone:
Gone:
Wasn't even going to to modify this one....that thought lasted a month
Lad took it off his car and I couldn't be bothered to split it down just for someone to reassemble it again.
Ok im just trying to get hold of the right Stainless Steel Pipe! Im aware I need around 2 meters of pipe to cut and bend in the right sections. However the problem now is that I cant find the right size inner pipe. They are either made in 63MM inner or 70mm Inner. 63MM i will have to flair out and 70MM flair it in. I just wanted a pipe like "65mm" that will sleeve on top of the current RS6 Stock Sports Exhaust.
What have you done Mike?
I took it to an exhaust fabricator and asked to to replace it. Easy peasy. It took him longer than I expected and cost me more because for some reason he thought I'd like some nice flanges. I'd have been happier with it just welded out.Shanghara wrote: ↑Fri Dec 14, 2018 2:04 pmOk im just trying to get hold of the right Stainless Steel Pipe! Im aware I need around 2 meters of pipe to cut and bend in the right sections. However the problem now is that I cant find the right size inner pipe. They are either made in 63MM inner or 70mm Inner. 63MM i will have to flair out and 70MM flair it in. I just wanted a pipe like "65mm" that will sleeve on top of the current RS6 Stock Sports Exhaust.
Photos of mine in this post:
viewtopic.php?f=121&t=119147&start=195#p799348
