Homelink Retrofit
4.2 V8 32v FSI - 444 bhp
Sammyb349
Homelink Retrofit
Post by Sammyb349 » Tue Nov 27, 2018 9:18 pm
Has anyone retrofitted the homelink? Hazzydays has it for £900 fitted but I wondered if this was diy’able. Also, does homelink have any MMI functionality - i’ve Never had it before but getting a roller garage door means I will want it! :boots:
Current:
- Audi B8 RS4 - Panther Black
Previous:
doodlebug
Re: Homelink Retrofit
Post by doodlebug » Tue Nov 27, 2018 9:28 pm
It’s a transmitter behind the grill and a trio of buttons, behind the sun visor.
Honestly I’d not bother. It is often painful on receiver compatibility too.
No MMI features.
Brooner
Post by Brooner » Wed Nov 28, 2018 8:57 am
some one on here due to the B9 RS4 not having these as an option now to spec the homelink buttons stuck the fob under the arm rest this could be a cheaper option
Surrey Sam
Post by Surrey Sam » Wed Nov 28, 2018 11:13 am
This is a retrofit I'm half way through. I've procured the correct roof console with switch and a transponder which goes behind the front grille rings. These have been installed but I hoped that wiring was in situ (it wasn't) so needed to order a kuftec harness, which was out of stock and I've not since looked again.
The car needs some coding, maybe some green menu tweaks, so that you can then use the MMI to programme the homelink remote to the car.
Sammyb349
Post by Sammyb349 » Wed Nov 28, 2018 2:44 pm
You are always one step ahead of me!
What cost do you think you are in for, all said and told. I don’t have ability to code the MMI.
Current:
Previous:
Surrey Sam
Post by Surrey Sam » Wed Nov 28, 2018 8:52 pm
:oops: :P Sorry about that.
I did a deal on eBay, got a Q5 roof console bit for £60 and the front transponder for £30. I then swapped the homelink buttons onto my own roof console, then removed front bumper to fit the transponder. A Kuftec harness is 49 EUR + postage so I should be under £200 when done as I already have VCDS to code with. That said, the Hazzydays price is good as they use new parts and obviously need to charge labour.
Once I have completed the DIY and cracked the coding, then I'd happily code yours.
Users browsing this forum: No registered users and 200 guests
