B9 Paddle Shifters
B9 Paddle Shifters
Throwing a query out there re above subject, having "again" seen a review in which B9 (maybe other?) paddle shifters get critiqued for being plastic-y and cheap feel. [Have own B9 on order, and so have some skin in the game with this query - not simply trolling].
I have so far only seen the RS5's paddles and, since they are same, would agree that the paddles are cheap feel in an otherwise superior quality cabin and for such a high grade car.
- Albeit subjective, is there general consensus that they are cheap in the context of RS4?
- Might any forum members know or have heard yet of 'quality' aftermarket paddle sources ie higher spec 'replacement' for B9 paddle shifters - ideally aluminium? Note : Not referring to Aftermarket 'Extension' Paddles
https://www.youtube.com/watch?v=0M1_YIU ... e=youtu.be
Current :Sonoma Green. Ext Black Pack, Carbon 'Ext/Eng Cover/Int trim', Sports Exhaust, RS Sports Int., Pana Sunroof, Matrix Lights, Park & Drive Assist pkg., Speed limiter removed, Titanium-Anthracite 20".
Previous : B8.5 RS4 Daytona Gray
Previous : B8 S4 Ibis White
Re: B9 Paddle Shifters
Every review, pretty much every single one, comment on the poor quality of the paddle shifters.
This is done strongest in the Henry Catchpole review where he compares the high quality ciggy lighter cover with the cheapo paddles and points out how Audi should be spending the money on the paddles on an RS, not the ciggy lighter.
Gone : 2017 M3 CP
Gone : 2007 B7 RS4 (
Gone : 2017 M3 CP
They are plastic and yup, they detract from the overall quality of the excellent interior just a little - however I rarely touch the things, maybe for a bit of engine braking on a long hill descent but that's about it. I wondered if the plastic wasn't a penny pinching exercise by cost-accounting but rather safety related, perhaps they are designed to snap off in the event of a hard frontal accident where the steering column collapses - seems possible.
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Terminator_X
I'd like the R8 paddles but no one can confirm if they fit. OE items work fine BTW.
TX.
TX.
They suck, I would have prefered metal ones and bigger too.
But to be fair I hardly use them. Box is 99% in auto.
All black B9 RS4
the 2014 R8 had lovely billet aluminium paddles that fitted the RS3
i know as i bought a set to fit to my B8 RS4 but the backing plate was too large so i sold these to Glenn
and he fitted them to his then RS3 so it could be possible that they would fit the B9 RS4 but some on would have to get a set and try to fit them
now if and when i ge a B9 RS4 i will be looking at this or getting a aluminium pads made to replace the standard set i pretty sure the black plastic backs could come off and an aluminium set made to replace them
i would like to see if i could find a capable metal worker to make the pads
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
- Graeme4130
I actually quite like the B9 paddles as they're nice and subtle, and easy enough to use
Racingline do a set of Aluminium paddle shifters. Look ok, but most likely a pain to fit as looks like you have to dismantle the Steering Wheel.
https://www.racingline.com/vwr494100
Current: 2018 RS4 B9 Avant
Gone: 2013 RR Evoque Dynamic Lux - Petrol
Gone: 2008 Mazda RX8 40th Anniversary Edition
- Surrey Sam
Slightly off topic but I think I would drive manual paddles most of the time, if only the HUD had a tacho.
Gone : 2017 M3 CP
Gone : 2017 M3 CP
Yes, agreed the HUD would look so much better - would just add to the experience.
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Doesn't the HUD have shift lights when you have them on the DIS (assuming you get them on the DIS like the C7)
Nah. It has 1) speed, 2) gear, 3) oil temperature and the biggest element is 4) a lap timer (the stupid lap timer I call it). Audi should check BMW, they have it sorted.
HUD is configurable in latest Porsches, that's best of course.
I expect Audi will sort this in the facelift coming next year.
Gone : 2017 M3 CP
Gone : 2017 M3 CP
Yes, it does project the shift light indicator in the hud.
(If you select that) box has to be in S.
All black B9 RS4
