I've been looking at NGK that a few tuners use for stage 2 I think ; https://www.ngk.com/product.aspx?zpid=10135
Upgraded Plugs
Upgraded Plugs
Can someone recomend some upgraded plugs? thinking of pulling the HP up to around 650 with DMS but before I do I want to change plugs out
2017 C7 RS6 PE Nardo
2014 911 991 C4S PDK White
2013 M6 Cab Blk
2012 911 997 MK2 PDK Silver
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
Re: Upgraded Plugs
Standard plugs are just fine for Stage 1, just need proper gapping
Re: Upgraded Plugs
I got mine stage 1 Apr and got plugs done but mustn’t be gapped properly when the car is ticking over it’s like it has a wee misfire you feel it through the car on tick over
Re: Upgraded Plugs
The tuners use NGK race plugs but not sure you linked the right ones.
Re: Upgraded Plugs
I'll speak to DMS anyone got a link of plugs that are the correct ones . Gsc what power are you running with map & Any other adjustments done with tune?
2013 M6 Cab Blk
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
Re: Upgraded Plugs
I think this is the correct type:
R7437-9 - NGK Spark Plug Sparkplug - Type : Racing - R74379 No. 4654
https://www.ebay.co.uk/itm/R7437-9-NGK- ... 1438.l2649
A quick on the forum for R7437 brings up a few hits:
search.php?keywords=R7437&fid%5B0%5D=76
Re: Upgraded Plugs
Or site Sponsor Opie Oils sell them for the same price as my ebay link but do a forum discount so go here:
https://www.opieoils.co.uk//p-64237-ngk ... kplug.aspx
Re: Upgraded Plugs
Thank you Mike your a gent.
2013 M6 Cab Blk
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
- Mr Footlong
Re: Upgraded Plugs
Hmm, MRC have quoted me for slightly different plugs when they remap next month. I like Opie, so would like to send some business that way and save a nice bit of cash, any thought on these NGK Racing 4905 plugs they want to go with, compared to the 4654 plugs mentioned above?
https://www.opieoils.co.uk/p-64238-ngk- ... kplug.aspx
Thanks!
Thanks!
Current:
Gone:
Gone:
Re: Upgraded Plugs
4905 is what anth linked to in his first post. Maybe they are the ones to go for then. I just quoted what had been posted on here before so may not be the ones of choice.
- Mr Footlong
Re: Upgraded Plugs
Oops, thanks. Ant, can you remember where you were told to go with the 4905 plugs? Based on what I was quoted I would say you are spot on, but I want to be sure too without phoning MRC to confirm, only to then buy them elsewhere cheaper!
Current:
Gone:
Gone:
Re: Upgraded Plugs
Mr Footlong wrote: ↑Thu Nov 22, 2018 5:39 amOops, thanks. Ant, can you remember where you were told to go with the 4905 plugs? Based on what I was quoted I would say you are spot on, but I want to be sure too without phoning MRC to confirm, only to then buy them elsewhere cheaper!
Hi mate, I'm sure these had been used in a Litchfield stage 3 build thead and I called the supplier to confirm last week. I'm sure both would do the Job . Are you going straight to stage 2 Footlong? You will have to let me know the results I've been itching for a while for stage one to get the boost a little more aggressive on feed in throttle (I think the c7 misses this a little)
2013 M6 Cab Blk
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
- Mr Footlong
Re: Upgraded Plugs
Yep, going to grab a set thanks. I hardly get to drive the C7 as I bought it for the wife. Not parting with my C5 any time soon and have managed to snag a TC to send away for upgrading for her, but I also work from home and so hardly get to drive anywhere full stop these days....
Current:
Gone:
Gone:
- Toffeebananas
- 1st Gear
Re: Upgraded Plugs
£30 a plug!!!!! Shites! Anyone find these cheaper anywhere else?
- uplandsway
Re: Upgraded Plugs
Toffeebananas wrote:£30 a plug!!!!! Shites! Anyone find these cheaper anywhere else?
Opie Oils sells them
rs246 at the checkout
Cheers,
Stevie F
2016 C7.5 RS6 Performance
Stevie F
