Hi, I'm currently building my s4 into rs4 spec and have k04 turbos, FMIC, RS4 injectors, rs4 Maf. I am looking for advice and for parts to cover the rest of the build, so RS4 lower inlet pipes (anyone have any?? or can you buy conversion kits that cover everything?, gaskets, seals etc?) and was also wondering if I can use my stock Maf housing with the new RS4 Maf? I'm also looking at a stage 3 clutch, or is this not the right thing to do, would rs4 or stage 2 S4 clutch be ok?
Also, as I've just crowned 200k miles should I bang out an engine rebuild as well? If so what parts other than gaskets and seals should I replace?
Any help appreciated.
Cheers,
AP
In need of some RS4/S4 parts and advice for K04 build.
Re: In need of some RS4/S4 parts and advice for K04 build.
Hi AP
I believe I have everything you need
Both turbos still in their bags from AET Engineering/ AET Motorsport
Plus all the other tubes,hoses and Y piece
I’m in Huddersfield
Give me a call if you are interested
07712 871586
Going out for the evening shortly
Text me if you get the message
Regards
Jason
I’m in Huddersfield
07712 871586
Regards
Jason
Banana man
- 1st Gear
MRC do a drive in and out service iirc.
200k is quite a few miles, if it’s a keeper then a rebuild wouldn’t be a bad idea, but it’ll get costly, how far do you want to go with it? As an engine with 200k is probably due a good overhaul, £1200 iirc just for chain tensioner now, and they are usually a good place to start along with new chains, a gasket set would be a good idea too considering the engine will be out, maybe even a measure up of the bores see if they have gone oval, and check for piston wear.
lower inlet pipes are either second hand genuine inlets or Xs power ones as iirc oem ones are now NLA.
You need to use the complete maf if you want to utilise the k04’s as the s4 maf tops out at about 400bhp, people can map on s4 maf’s but once the maf tops out the engine runs blind, the RS4 maf is larger diameter hence the capability to measure more air.
I’m not so clued up on clutches, depends also if you want oem feel or could live with a paddle clutch, also SMF and deal with the chatter or keep DMF.
Good advice about the engine above. I would get it professionally checked, bores, compression, tensioners, chains, oil leaks, all the usual stuff.
Banana man
- 1st Gear
I’ve just seen the OP’s posting date, he probably doesn’t even own the car anymore.
