I have done about 800 miles mainly motorway though and returned about 24.1 MPG overall, not sure how that compares to the rest of you but it is worse than the S4 where using the same driving types I could get to about 28MPG, although I think that is to be expected.
Handling, much better than the S4, Tighter, ride no worse, a lot more positive and less understeer.
Steering, not so good here, the RS4 likes to "track" over everything, I am sure if you were to draw a chalk line on the road it would even follow that
Engine, Here is where the big difference is, my S4 although tuned by AMD delivers a very different power curve, no real boost point, but tons of lovely fat torque was everywhere in the rev range, although it did run out of puff above about 6000.
The RS4 has a definite power band with not a lot below 3000, then it all comes in a rush and keeps building to the red line, it means that you have to keep it spinning when pushing on a bit otherwise it behaves a lot like a big turbo'd EVO.
It means that at about 80 on the motorway I thiink my S4 would leave it for dead until it got on boost, although I have to say my S4 is particularly strong in this area, probably say the same for A/B roads where the huge torque right across the rev range just made tons of overtaking opportunities open up, most not needing a down change, the RS4 needs to be worked at a little more thats all.
I thought my "Bum dyno" would be able to feel the 60hp difference between my S4 and the RS a lot more than it does, I guess it is the way that the RS makes it's power.
Anyway thinking about Mods now, suspension maybe H&R, and would like to get the engine to 450 - 460 with a fatter flatter torque curve, and RS6 Brakes should just about do it, but overall I am over the moon with it, especially the looks that you get from those in the know, and the way that it fires itself out of roundabouts in 2/3rd gear with no drama just a wail from the exhaust and space shuttle like acceleration
