Just to flag that it's worth subscribing to ECP for updates. You get spammed (a lot) but it can pay off if you're after discs in particular - I managed to bag a pair of front discs (Zimmerman plain left/right handed) for £340 delivered (plus £11 Quidco cashback) via a flash sale code I just noticed in time, earlier this week.EireRS6 wrote:The 2 front discs came to £346. Bargain.
Discount code for ECP is MAY75 if anyone's interested.
Sent from my SM-A520F using Tapatalk
Front discs & pads
Re: Front discs & pads
Happy with those.
(Pics show the L/R stamped codes as 2357/2367, for reference, in case anyone needs that info in the future).
Not drilled ?
Correct. Plain (like the originals fitted to mine). Greater friction surface, less likely to crack, no dust build up in the holes, quieter, etc. Arguably more prone to fade, but fine for my driving style.Mark-RS wrote:Not drilled ?
^Same reasons I use plain disks where possible. No choice on the C6 disks unfortunately.
Looks like ECP are offering 50% off again, but for the next few days (rather than just a 2 hour 'flash sale').
Brings a set of Zimmerman fronts down to £339.99 delivered, using code 'HALLOWEEN80', if anyone's interested
Links: Front Left, Front Right
Bargain.
Bloody good value that.... Kind of makes me wish I needed front discs.....
On the grooved / drilled / plain debate... Grooves are a good thing. They clear dust away from the pad surface which helps the pad wear evenly and can help with the initial bite when you hit the brake.
Drilled I'm not a fan of. Meant to aid cooling but they are prone to cracking. Cons outweigh the pros in my opinion....
Had no issues with my drilled ones. Had grooved on other cars and they are for sure noisier than I would have liked. Only thing I have noticed with mine is they are slightly squeaky when cold or not pressing hard, like in traffic or something.
Thanks for the heads up I've bought a set of fronts. Not in a rush so can happily wait till they come in stock again.
I wasnt too fussed about having plain discs this time as I found my previous drilled discs very prone to warping. Shall see how I get on with these.
NP. Yeah, no rush for me either - mine are likely to sit in my garage for several months until actually needed, but good to keep the C5 store cupboard topped up!Gripper1 wrote:Thanks for the heads up I've bought a set of fronts. Not in a rush so can happily wait till they come in stock again.
Same here. I bought the solid Genuine Audi set off EBay. Managed to get 15% discount using an eBay code so they were just over £350 deliveredGripper1 wrote: ↑Fri Oct 26, 2018 9:03 amThanks for the heads up I've bought a set of fronts. Not in a rush so can happily wait till they come in stock again.
Received an email from ECP today stating they are unable to supply the discs and are cancelling my order.
That sucks.Gripper1 wrote:Received an email from ECP today stating they are unable to supply the discs and are cancelling my order.
Users browsing this forum: philS2 and 98 guests
