Disable boot open with key fob
4.2 V8 32v FSI - 444 bhp
mikep99
Post by mikep99 » Mon Oct 15, 2018 12:13 pm
Hi All,
Asking on behalf of a friend who has a 2014 RS4.
He's recently had a couple of instances when his boot has been open when he's returned to his car.
It sounds like quite a common 'feature' after reading a good few posts online whereby the slightest of presses on the key fob opens the boot.
I couldn't find a definitive answer as to whether this can be turned off via VCDS.
Any of you guys been able to disable the remote boot opening?
Or have any info. as to whats required if its at all possible?
Thanks in advance
Mike
Re: Disable boot open with key fob
Post by MikeFish » Mon Oct 15, 2018 1:33 pm
It shouldn't open with a slight press. Needs a long press to open.
On the C7 I can change all the parameters using VCDS but I think someone looked on the B8 before and it didn't have the same settings.
mikep99
Post by mikep99 » Mon Oct 15, 2018 2:13 pm
OK, thanks for the info.
Mike
Sent from my PRA-LX1 using Tapatalk
