Wingback retro fit in B8, how to resolve side airbag light
Re: Wingback retro fit in B8, how to resolve side airbag light
Changed title, as not getting to much takers on resolving my problem, anyone get an idea what resistors amp to use or is there a plug a play option still available (old post mention options from Germany) can’t seem to find any recent links.. final note, any Anglian based Vag Com members who’d be willing to code out for beer tokens
Current ride’s
Previous rides
Previous rides
Quick if you know what amp is required
Thanks for sharing, did use them?
Do I just need these for each plug?
I have not used them. But if you look through the sellers details it sure looks like this is a business that deals specifically with this product. Why don’t you email/contact the seller and speak to them directly about your needs.
Ps. It is the resistance value (ohms) you need to know not Amps.
Current ride’s
Previous rides
Previous rides
Thanks again, will do that..Eddie555 wrote:I have not used them. But if you look through the sellers details it sure looks like this is a business that deals specifically with this product. Why don’t you email/contact the seller and speak to them directly about your needs.
Ps. It resistance value you need to know not Amps.
Was after a forum recommendation,
Great lot of helpEddie555 wrote:I have not used them. But if you look through the sellers details it sure looks like this is a business that deals specifically with this product. Why don’t you email/contact the seller and speak to them directly about your needs.
New message from:
Hi sorry I can't confirm what you need also I can't confirm that they will work or put your airbag light out.
No instructions are provided as in description.
You'll have to do your homework.
Regards
John.
Ok. Try this get a multimeter set it to read OHMS. Take your old resistor and measure the value. It obviously worked in the past albeit it being fitted really badly. If it reads 2.2 ohm then that eBay sellers resistor will work fine.
Current ride’s
Previous rides
Previous rides
- Surrey Sam
The fault code will always need to be cleared first, it (airbag light) won't go out despite all of your efforts.
I haven't the time to devote to helping at the moment, but good on Eddie for stepping in
I've used 4.7 ohm rated resistors on my B7 with no problems -
https://www.ebay.co.uk/itm/Airbag-SRS-r ... 8ejmpafQtg
https://www.ebay.co.uk/itm/4-7-OHMS-SRS ... Sw2gxYoFP9
Mike
Mike
Noted, will try clearing..Surrey Sam wrote:The fault code will always need to be cleared first, it (airbag light) won't go out despite all of your efforts.
Is it only Vag Com to do so, is there no hand held device that does the trick
Yes some cheap hand held can clear airbag fault codes . Do a search on ebay . As for your cut wires I would solder the plugs onto the original loom and heat shrink the joints . Then buy another two plugs / repair wires from Audi and source the 4.7 ohm resistor as mentioned . Join wires and resistor as you found but properly soldered and heat shrunk . That would be similar to how Recaro use to sell them for people wanting to fit pole position's in cars equipped with seat airbags .
Had codes cleared, lights out now
looks like it’s sorted.. after what must of been a poor connect with both or one of the resistors
looks like it’s sorted.. after what must of been a poor connect with both or one of the resistorsSent from my iPhone using Tapatalk
How did you resolve the dodgy put together resistors?
Current ride’s
Previous rides
Previous rides
Soldered them & insulation tape & plugged them back in..
Sorry to dig up an old thread but wondered if anyone can help.
I fitted genuine RS4 wingbacks in my B8.5 RS4, has 4 codes. Cleared the 2 for the side airbags by fitting resistors but still have 2 for seat position sensors
I believe it’s possible to code the airbag module for these seats but I’m struggling to find any information. Someone has provided me a code of 0430622 but for the life of me I can’t work out where this would be entered into the airbag module using VCDS
Users browsing this forum: Google [Bot] and 23 guests
