Was hoping my old C5 RS6 scan tool would work, as I have an airbag light on.
Can anyone suggest a scan tool, used this on my old RS6
Also his came up today
Any ideas
Surrey Sam wrote:VCDS works for me, the programme is loaded onto a laptop and then you plug the cable in and connect. You can do a lot of stuff with it.
Odd how that airbag light has just popped up, I did notice when you first posted pictures of your car that the Bucket seats are retrofitted and obviously the steering wheel re-trimmed. So maybe a connector/wire come loose? It'll have logged a code which will help point you in the right direction. If your anywhere near me, then I'll happily pull the codes for you.
Surrey Sam wrote: ↑Mon Oct 01, 2018 10:09 amResistors and professional I wouldn't perhaps use together. The buckets don't have side airbags in them, so like I commented in that thread you linked, the car needs to be re-coded so that it doesn't look for them. The resistors are a work around to try fool the system.
So I'd suggest that's where your problem is (the cut wires). It may be a resistor that has failed, incorrectly sized or a solder joint gone bad, you'll need to look under the seat as that's where the plugs are. Undo all 4 seat rail bolts and then tip the seats backwards for a better look, grab a picture and then post back and I might be able to see what's going on.
Any views of the pics..jangol wrote:
Pics of passenger side plugs??
Thanks for pic,Surrey Sam wrote:Well the Blue and Black wires have been cut and they're for the side airbags, have you un-ravelled the tape going down the side of the yellow connector to see what going on there. That's your side airbag plug and where the resister should be I'd have thought.
Here's mine (normal seats) for reference.
Quality bodging!jangol wrote: ↑Sun Oct 07, 2018 4:52 pmProfessional install my butt.. Not an ounce of solder anywhere. Anyhow, any ideas on how I can resolve this issue, do the black & blue cables from main loom need to join the yellow plug & resistor also?
or just need a good purchase between plug & resistor
